Wired Intelligent Edge
aruba 2920
  • 1.  aruba 2920
    Posted Sep 29, 2017 02:14 AM
    Customer have 2 plaint office
    In Plaint 1 office:
    - using 30m red tone internet
    - HP OfficeConnect 1910
    - firewall ip address 192.168.100.1
    In Plaint 2 office:
    - Aruba 2920-24G
    switch settings are as below
    ; J9726A Configuration Editor; Created on release #WB.16.02.0012
    ; Ver #0e:01.b0.ee.34.5f.3c.29.eb.9f.fc.f3.ff.37.ef:73
    hostname "MYPCSBCSW001-DATA"
    module 1 type j9726a
    aruba-central disable
    no rest-interface
    timesync ntp
    ntp unicast
    ntp server 192.168.100.1 iburst
    ntp enable
    time timezone 480
    ip default-gateway 192.168.100.1
    ip route 0.0.0.0 0.0.0.0 192.168.100.1
    ip routing
    snmp-server community "public" unrestricted
    oobm
    ip address dhcp-bootp
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1-24
    exit
    vlan 2
    name "VLAN2"
    untagged 3-19,24
    tagged 1-2,21-23
    ip address 192.168.100.6 255.255.255.0
    exit
    vlan 10
    name "MANAGEMENT"
    tagged 1-2,20-23
    ip address 10.60.2.254 255.255.255.0
    exit
    vlan 12
    name "EndPoints"
    tagged 1-2,20-23
    ip address 10.60.6.254 255.255.255.0
    ip address 10.60.7.254 255.255.255.0
    dhcp-server
    exit
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    dhcp-server pool "EndPoints"
    default-router "10.60.6.254"
    dns-server "192.168.100.16"
    lease 00:04:00
    network 10.60.6.0 255.255.255.0
    range 10.60.6.2 10.60.6.250
    exit
    dhcp-server enable
    password manager
    Question is
    - now plaint 2 office want to install new firewall with new internet line and want to be primary line, he want to remail previous line as backup if new line down, he will turn off firewall and will switch over to old internet line
    - Firewall ip is 192.168.10.1
    so i add
    ip route 0.0.0.0 0.0.0.0 192.168.10.1
    vlan 5
    name "TIME INTERNET"
    untagged 23 -> this port connect to new firewall
    ip address 192.168.10.2 255.255.255.0
    exit
    Problem is, i try to ping 192.168.10.2 i will receive a reply  but when i ping to 192.168.10.1 it has no responding, whats wrong with my settings?
  • 2.  RE: aruba 2920
    Posted Oct 03, 2017 05:45 AM
    I usually wouldn't entertain these types of posts, but curiosity is getting the better of me. This is how I go about diagnosing every issue, whether believed to be networking or application, and every layer in between. I base my thought process on the 7 layer OSI model. Starting from layer 1 and ending up at 7. Do not skip any steps and don't just say you did a step as someone will find out.
    I live by two rules before I even start to diagnose any issue. (a) can I predictably repeat the problem that I am seeing? and (b) do not make any changes until I am confident this change fixes the issue or helps clarify point (a).
    Then the diagnosis. We need to ask ourselves questions:
    Firstly, are we confident Layer 1 is working
    Is it plugged in? Do we have link lights? If a link is fibre, do we have light coming out of one of the fibres? is it the right strand of fibre? Is it terminated on the correct patch panel port? What does the switch think about the port(s)? Type the commandShow interface status. is the "link status" or link state showing up and the port enabled?
    Are we confident Layer 2 is working
    are we learning MAC addresses on the correct ports? type the show mac-address  command. Is the layer 2 VLAN created on the switch? Is that port in the correct VLAN? is the source and destination MAC in the same VLAN? are they supposed to be in the same VLAN? Is the MAC flapping between multiple ports? Is the port showing any packets or frames? are the packets all in one direction (TX or RX counters)?
    Are we confident Layer 3 is working
    Does the Layer 3 device have the right MAC lined up to the right IP Address? Is it the same MAC above? Command: show ip arp and show ip route. Does the show ip route point the IP in the correct direction / or attached to the right VLAN that you checked in Layer 2? Is the route learnt the expected way (Static/Connected/OSPF/BGP/etc.)?
    And so on we go... As you said Pinging the IP address of the firewall is not possible that's a Layer 3 problem, which means any layer below this symptom could be the cause. If you find that it's a layer 2 problem, like the switch is not learning the MAC address on that port, then it's a Layer 2 or Layer 1 problem. From here we can eliminate each layer from the equation.
    There are tools and questions we need to ask of every layer in the model. One last example is in Layer 4 we can use CLI and Telnet to check if the TCP port we need is open and establishing connections (4 way handshakes for example). It's very easy to say an application is running slow, but working through the layers systematically will expose the root of the issue. Our aim in this method is to identify the issue as low as possible or to prove (and be confident) that the issue is not in our layer of responsibility as network engineers.
    Even after all those rules and suggestions, my random guess is the firewall probably isn't responding to ping/ICMP by default/design. Your symptom doesn't sound suspicious to me at all. You might actually find that you don't have a problem at all :)
    Cheers
    Grocke
  • 3.  RE: aruba 2920
    Posted Oct 03, 2017 02:56 PM
    You simply cannot have configured these three commands at the same time on the switch:
      ip routing
    If you want to maintain the switch using only L2 erase
      ip routing
    But if you want to add L3 routes erase
