Wired Intelligent Edge
Aruba 2920-48G-PoE+ reboot after cable-diagnostics job
  • 1.  Aruba 2920-48G-PoE+ reboot after cable-diagnostics job
    Posted Aug 14, 2018 10:53 AM
    Dear community,
    today I created a job on an Aruba 2920-48G-PoE+ (J9836A) firmware version WB.16.02.0022m, which should perform a daily cable diagnosis on certain ports.
    job run-cable-test at 15:15 on mo,th,we,tu,fr,sa,su "test cable-diagnostics 38-42"
    During the execution of this job, the switch restarted.
    Could it be a bug or is the "test cable-diagnostics" command simply not suitable for use in a job?
  • 2.  RE: Aruba 2920-48G-PoE+ reboot after cable-diagnostics job
    Posted Aug 14, 2018 01:09 PM
    I have just tested the job on a fresh 2540 48G PoE+ 4SFP+ (JL357A) firmware YC.16.02.0012.
    The behavior is identical, the switch restarts after the command has been executed.
    "Test cable-diagnostics" simply does not seem to be suitable for use in a job, too bad.
  • 3.  RE: Aruba 2920-48G-PoE+ reboot after cable-diagnostics job
    Posted Aug 14, 2018 08:20 PM
    Hi!
    I've validated this exact same behavior in our lab on that exact same build of YC.16.02.0012 using a 2540.  However, it works fine with YC.16.06.0006.
    It looks like according to the 16.03 release notes, there was a similar issue and it was fixed then.  I would recommend updating your firmware to 16.03 or later.
    https://support.hpe.com/hpsc/doc/public/display?docId=c05363775
    We will investigate getting this fixed for the 16.02 train of code.
    Justin
    JUSTIN NOONAN
    TECHNICAL MARKETING ENGINEER – ARUBA WIRED INTELLIGENT EDGE
    O: +1 916 540 1748   |   justin.noonan@hpe.com
    8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747 USA
