And the default gateway 192.168.25.1 is reachable on one of your interfaces?
Original Message:
Sent: Dec 07, 2023 05:01 AM
Subject: Aruba 2920 static routing
Hello Herman,
Thnaks for your response. I tried that but the second route still doesn t figure on the table but surprisingly, the first route always does.
Original Message:
Sent: Dec 06, 2023 08:50 AM
It may be that the show route only displays active routes. A backup route may be considered not active.
You may validate this with TAC... or bring the interface connecting to your primary route down.
Original Message:
Sent: Dec 04, 2023 06:18 AM
Hello Community,
Any can bring an explanation to it ?
Original Message:
Sent: Nov 30, 2023 05:05 AM
Hello
I added a second default route through ip route 0.0.0.0 0.0.0.0 192.168.25.1 metric 3 name backup-route but I can not see it on the routing table through show ip route static even though the interface to the gateway is up. Any help ? Thanks
