Wired Intelligent Edge
Aruba 2920 SW with VXrail Server configuration required
  • 1.  Aruba 2920 SW with VXrail Server configuration required
    Posted Mar 12, 2017 05:21 AM
    I have new Vxrail server to installation
    i have switch requirment.
     3 vlan,
    Managment(untagged)
    Vmotion ( Non routeable )
     VSAN  ( Non routeable )
    total 8 ports for vxrail server
    *  trunk mode ( accept all vlan)
    * disable ( LACP / Ethernet channel )
    *IPV4 / IPv6  Multicast enable
    what is command for this requirtmen in Aruba 2920 switch.
    i used for LACP disable
    No lacp in ports
    what is other commands will accept Vxrail server requirment.
  • 2.  RE: Aruba 2920 SW with VXrail Server configuration required
    Posted Mar 21, 2017 05:46 PM
    Not sure if I fuly understand your question. I'm not sure if there are very special requirements for vxrail servers but if you want to create a vlan you can do that with following command:
    - vlan <number>
    LACP or Trunk you already found I saw in the message.
    To accept all the VLANs on the different ports you will need to add all VLANs as tagged on these ports or two tagged and one untagged but depends how you network infrastructure is configured.
    From the email I think you just need to forward in controlled manner the multicast packets this can be done by IGMP (IPv4) and MLD (Ipv6).
    Hope this helps.
     3 vlan,
    Managment(untagged)
    No lacp in ports
     3 vlan,
    Managment(untagged)
    No lacp in ports
