Wired Intelligent Edge
Aruba 2920 Upgrade Path
This thread has been viewed 36 times
  • 1.  Aruba 2920 Upgrade Path
    Posted Sep 29, 2021 10:12 AM
    Hello guys
    Im about to upgrade many switches 2530s. 3810,2920
    I could see on the realise note that on the 3810 and 2530 there is like a minimum version in which you need to have the switch to upgrade it directly or at least thats what i understood(im not a native english speaker)
    For example for a 2530 it shows this table
    I could see a similar table for 3810 but for a 2920 there is a separate release note and there is not a minimum supported area in the release note
    My 2920 are really olds
    version 16.03.0004 in one 2920 o and  15.18.0010 in the other one.
    Could you guys help me to know if i can upgrade directly or there is a proper upgrade path for this?
  • 2.  RE: Aruba 2920 Upgrade Path
    MVP GURU
    Posted Sep 29, 2021 11:45 AM
    Hi, the HP ProCurve 2920 (now called Aruba 2920) with HP ProVision WB.16.03.0004 (April 2017) could be upgraded to latest ArubaOS-Switch version WB.16.10.0016, both the source and destination versions use the same BootROM version (WB.16.03) so you should expect just a single reboot during the entire upgrade procedure (WB.16.03.0004->WB.16.10.0016).
    The WB.15.18.0010 is one year earlier (April 2016) than the WB.16.03.0004 and it should probably run with the BootROM version WB.15.05 so you can either go to WB.16.10.0016 (and expect TWO reboots, the first due to the BootROM update, the second due to the Application Software update) or go via an interim release carrying the BootROM WB.16.03 (exactly the WB.16.03.0004, as example <- keep in mind that, as example, the WB.16.02.0010 of August 2016 carried the BootROM WB.16.02...so if you plan to go through an interim release like the WB.16.02.xxxx then expect the Switch to reboot twice since the BootROM will be upgraded...and then the same will apply between the WB.16.02.xxxx to the latest WB.16.10.0016)...IMHO...you could perform a straight upgrade process from WB.15.18.0010 to WB.16.10.0016 (and just be prepared to see the Switch to reboot twice automatically but just one time only). The "watershed" is, for what I recall, the WB.16.03.xxxx which carried the same BootROM version we see on today latest ArubaOS-Switch versions.
    Davide Poletto
  • 3.  RE: Aruba 2920 Upgrade Path
    Posted Sep 29, 2021 11:57 AM
    Thanks Davide for your excellent response in this topic!
    Now im aware of what will happen, and like always i will take my backups of everything before
    Cheers
    Carlos
  • 4.  RE: Aruba 2920 Upgrade Path
    Posted Oct 14, 2021 11:26 AM
    Hello Parnassus
    Questions
    This would apply to other swithces like 2530, 3810  and 5406?
    Or at least with a switch like 5406 its different?
  • 5.  RE: Aruba 2920 Upgrade Path
    MVP GURU
    Posted Oct 14, 2021 08:15 PM
    Hi Carlos, well each ArubaOS-Switch based Aruba Switch series (KB, WC, YA etc.) - and that is clearly valid also for older HP ProVision based HP/HPE Switch series (do not forget that the current AOS-S OS is the rebranded and developed reincarnation of the old HP ProVision OS born and used on the now legacy HP ProCurve switches) - continues the software branches approach (example: XX.15.yy, XX.16.yy) and within each software line there are various builds (example: from XX.16.10.0001 to 0010) and only by checking their Release Notes you can verify all update restrictions and requirements eventually declared...things change rarely...but, in any case, you should first verify what is your starting software condition (show version, show flash) and then you can plan the update to the desired supported software build...generally there are less restrictions in upgrading than in downgrading...so once you check that BootROM version doesn't change and once you have digested and approved any new feature/bug fix as per those Release Notes...the software update will be generally a (one step) painless process. There are exceptions but, again, Release Notes are a quite good source to help you plan the right update approach (via an interim step or one step). Hope this clarify your doubts.
  • 6.  RE: Aruba 2920 Upgrade Path
    Posted Sep 29, 2021 11:54 AM
    - removed - crossed with the earlier reply
