The ap is flashing blue flashing every 5 seconds, meaning network connectivity loss.
This is what the switch shows when you run command
show power-over-ethernet 24
Status and Configuration Information for port 24
Power Enable : Yes PoE Port Status : Delivering
PLC Class/Type : 3/1 Priority Config : high
DLC Class/Type : 0/- Pre-std Detect : off
Alloc By Config : usage Configured Type :
Alloc By Actual : usage PoE Value Config : n/a
PoE Counter Information
Over Current Cnt : 0 MPS Absent Cnt : 0
Power Denied Cnt : 0 Short Cnt : 0
Power Information
LLDP Information
PSE Allocated Power Value : 3.2 W PSE TLV Configured : dot3, MED
PD Requested Power Value : 0.0 W PSE TLV Sent Type : dot3
MED LLDP Detect : Disabled PD TLV Sent Type : n/a
PSE Voltage : 55.3 V PSE Reserved Power : 3.2 W
PD Amperage Draw : 57 mA PD Power Draw : 3.2 W
Tim Black
Original Message:
Sent: Dec 07, 2021 03:06 PM
Subject: Aruba 2930 AP disconnects
Have you taken a look at the light status ? https://help.ui.com/hc/en-us/articles/204910134-UniFi-LED-Color-Patterns-for-UniFi-Devices
What do you get when you issue the "show power-over-ethernet 24" command when the AP is up and blinking?
Dustin Burns
Lead Mobility Engineer @WEI
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
Original Message:
Sent: Dec 06, 2021 06:32 PM
We set up a Unifi AP Nano to switch 2930 using VLAN201 port 24 untagged.
AP powers up and can be seen, then a couple of seconds later it drops and the disconnects (Goes to a flashing blue light instead of being solid.
Any help would be great!
Here is my switch config:
| ; JL558A Configuration Editor; Created on release #WC.16.05.0007 |
| ; Ver #12:08.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:ba |
| password minimum-length 5 |
| time daylight-time-rule continental-us-and-canada |
| ip default-gateway 10.0.149.254 |
| snmp-server community "COA-RO" unrestricted |
| snmp-server location "FS5-3" |
| name "1: Servers 10.0.0.x/24" |
| name "10: Phone 10.0.100.x/23" |
| name "102: City Hall 10.0.2.x/24" |
| name "103: PHA 10.0.3.x/24" |
| name "104: DPS/Fire 10.0.4.x/24" |
| name "105: Rec Ctr 10.0.5.x/24" |
| name "106: Library 10.0.6.x/24" |
| name "107: ASC 10.0.7.x/24" |
| name "108: Yards/AC 10.0.8.x/24" |
| name "149: Switch Mgmt 10.0.149.x/24" |
| ip address 10.0.149.87 255.255.255.0 |
| name "200: P2P Bridges 10.0.200.x/24" |
| name "201: WirelessAP 10.0.201.0/24" |
Tim Black
