Aruba 2930 + Central
  • 1.  Aruba 2930 + Central
    Posted Apr 02, 2019 06:12 PM
    Good day community!
    I need help with a switch in which I'm working.
    My switch has multiple vlan interfaces and some of them are not allow to pass through my firewall. I am trying to bring this switch to central but I don´t know how.
    Is there any way to force a source interface when the switch is trying to reach central?
    For example: All my request going to central will have as source the interface VLAN 100
  • 2.  RE: Aruba 2930 + Central
    MVP GURU
    Posted Apr 03, 2019 01:58 AM
    Look ip source XXX interface... command
  • 3.  RE: Aruba 2930 + Central
    Posted Apr 03, 2019 01:21 PM
    Greetings!
    To designate a specific VLAN to be used for connections to Aruba Activate, Central, and AirWave, you need to use the primary-vlan command, as in the example below:
    switch(config)# primary-vlan 100
    If a primary VLAN is not configured, the switch will attempt to use VLAN 1 for all connections to these platforms.
  • 4.  RE: Aruba 2930 + Central
    Posted Apr 05, 2019 03:07 PM
    Good day community!
    Thanks a lot for your answer! I will be testing this configuration with the customer any time now.
    I tried the configuration of ip source but I didn't work. For some reason I was specifying the interface to be VLAN 1 and I wasn't getting an aswer back. I even create and allow a new IP with privileges to access the network and didn't work.
