Network Management
  • 1.  Aruba 2930 no web interface
    Posted Jul 24, 2024 05:58 AM
    Hi, everything I have read tells me the web interface should be enabled by default, but it is not working.
    I can ssh to the switches, if I go onto the switch and run "telnet <localIP> 22" I get the ssh banner, if I do the same test on port 80 and 443 it just times out. sh run | i http and sh run | i web doesn't bring up any results.
    Its just a basic switch single mgmt Ip, no vrfs's in fact I have 10 of them none of them have a responding web interface and they are on varying firmware's. Is it something to do with password manager?
  • 2.  RE: Aruba 2930 no web interface
    Posted Jul 24, 2024 06:07 AM
    I have the following configuration in my switch:
    no web-management
    web-management ssl
    You may try to run: 'web-management ssl' or 'web-management plaintext' to explicitly enable https (or plaintext = http) and see if an error shows up indicating why it may not have been enabled. I can imagine that you need to set a manager password before you can enable the web-management, but not sure. Setting a manager password: "password manager".
  • 3.  RE: Aruba 2930 no web interface
    Posted Jul 24, 2024 06:57 AM
    Edited by KDN Jul 24, 2024 08:26 AM
    Ok my apologies, seems port 80 was open it was a firewall block! even though no response on port 80 using the built in telnet client, maybe that's just how it is.
