Wired Intelligent Edge
Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
  • 1.  Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
    Posted Mar 08, 2018 11:03 AM
    Hi Guys (and of course girls),
    I'm a little bit stuck in an IRF-Configuration and i hope you all somehow can help me a little.
    I've set up an IRF-Stack of 6x HPE 5700AF Switches with a 20GBit/s IRF-Link as a Ring. To prevent Split-Brain-Situation i wanted to set up LACP-MAD with an assist device. (customers wish for a seperate device...)
    Here I wanted to use one Aruba 2930F Switch with 3x 1G RJ45 Ethernet for the local Stack-Members and 3x 1G SFP-Fiber for the remote devices (different building about 650ft/210m away).
    I actually don't know how to set those devices correctly up.
    Right now i created a Link-Aggregation on the IRF with 6 member ports an the MAD-VLAN 3999 as access ports. On the 2930F i created a lacp-trunk with 3 copper and 3 fiber ports and the same access-vlan.
    Here is the moment where i got stuck.
    On the a-Series Switch stack i activated lacp-mad.
    But what to do on the Aruba switch?
    Maybe someone can support me with a corerct mad-Config on the A-series switch and a correct assist-config for the 2930F device...
    Would be nice.
    Any idea appreciated!
    Franz
  • 2.  RE: Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
    Posted Mar 13, 2018 03:33 PM
    At the comware switch configure a dynamic link-aggregation interface. In the bridge interface enter the command “mad enable”.
    At the 2930f switch create a trunk interface with lacp. Within the trunk interface enable mad passtrough. For example: “interface trk1 lacp mad-passthrough enable”
    To validate the passtrough use the command “show lacp mad-passthrough counters”
    To validate if mad is working enforce a split brain.
  • 3.  RE: Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
    Posted Mar 26, 2018 08:25 AM
    Believe it or not. I had configured all correct. It did already work.
    I just missed the command "show lacp mad-passthrough" as only this showed me (and the customer) that it was already working.
    The Comware-Switches told us already that MAD was doing OK and all the members were seeing each other...
    THANK You for saving my day
  • 4.  RE: Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
    Posted Mar 26, 2018 08:27 AM
    BTW: Will this work with an HP/Aruba 2920 as well? At least in the Documentation it says something about mad-passthrough...?
  • 5.  RE: Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
    Posted Mar 26, 2018 09:02 AM
    I think this will also work for the 2920 switches
  • 6.  RE: Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
    Posted Mar 26, 2018 09:03 AM
    THX
