Wired Intelligent Edge
Aruba 2930F inter VLAN routing
This thread has been viewed 45 times
  • 1.  Aruba 2930F inter VLAN routing
    Posted May 29, 2019 01:57 AM
    Goals :
    1. Separate LAN into 3 different VLAN
    2. Granting access to the Internet to those 3 VLAN through VLAN 1000
    Issue : Unable to access the Internet from a PC connected to any of those VLAN : 100,110,120. I attached my configuration. I think I missed something important. Any help much appreciated.
    Test environment
    Router Edgerouter X configuration
    • LAN IP : 192.168.22.1/24
    • Static routes :
    configure
    set protocols static route 192.168.100.0/24 next-hop 192.168.22.253
    set protocols static route 192.168.110.0/24 next-hop 192.168.22.253
    set protocols static route 192.168.120.0/24 next-hop 192.168.22.253
    commit
    save
    SWITCH HP Aruba 2930F VLAN configuration
    VLAN No
    Description
    VLAN IP
    Port
    1000
    VLAN interconnection
    192.168.22.253/24
    Untagged : 1-2
    100
    CS department
    192.168.100.253/24
    Untagged : 3-4
    110
    General affairs department
    192.168.110.253/24
    Untagged : 5-6
    120
    Finance department
    192.168.120.253/24
    Untagged : 7-8
    SWITCH HP Aruba Aruba-2930F-8G-PoEP-2SFPP whole configuration
    ; JL258A Configuration Editor; Created on release #WC.16.05.0007
    hostname "Aruba-2930F-8G-PoEP-2SFPP"
    module 1 type jl258a
    ip default-gateway 192.168.22.1
    ip routing
    no ip source-route
    snmp-server community "public" unrestricted
    vlan 1
      name "DEFAULT_VLAN"
      no untagged 1-8
      untagged 9-10
      ip address dhcp-bootp
      exit
    vlan 100
      name "CS department"
      untagged 3-4
      ip address 192.168.100.253 255.255.255.0
      dhcp-server
      exit
    vlan 110
      name "General affairs department"
      untagged 5-6
      ip address 192.168.110.253 255.255.255.0
      exit
    vlan 120
      name "Finance department"
      untagged 7-8
      ip address 192.168.120.253 255.255.255.0
      exit
    vlan 1000
      name "VLAN interconnection"
      untagged 1-2
      ip address 192.168.22.253 255.255.255.0
      exit
    management-vlan 1000
  • 2.  RE: Aruba 2930F inter VLAN routing
    Posted May 29, 2019 03:19 AM
    Can you try to add to the switch an 'ip route 0.0.0.0 0.0.0.0 192.168.22.1'. Check this post to see that ip default-gateway is just for the switch itself in 'no ip routing' mode.
    Also if that doesn't work, check on your router if it will perform NAT for all traffic coming into the LAN interface, or just for the subnet on that interface. Some routers only NAT or allow traffic from the subnet, not if it is routed like in your case.
  • 3.  RE: Aruba 2930F inter VLAN routing
    Posted Apr 17, 2020 03:23 AM
    hello,
    I have exactly the same problem with my Aruba 2930F in combination with my Netgear Nighthawk X4 router and I am thinking about buying a EdgeRouter X to solve this problem, did the issue with the inter VLAN routing not working ever get fixed ?
  • 4.  RE: Aruba 2930F inter VLAN routing
    Posted Mar 13, 2021 09:32 PM
    Please note that 2904F series switches do not have layer 3 ports to perform routing to the upstream device.
    Instead the uplink connection is a trunk link, and all vlans must be tagged on the uplink interface of the 2903F.
    For example
    If you are connected to mikrotik router board, configure vlans and their corresponding ip addresses, and map all those vlans to the ethernet port or interface connecting to 2903F.
    With this all vlans will reach the internet.
    Prosper Mbabazi
