ARUBA 2930F (JL253A)
  • 1.  ARUBA 2930F (JL253A)
    Posted Aug 07, 2020 08:23 AM
    hello good morning, I would like to know how to configure a port on access, the commands via cli does not work
  • 2.  RE: ARUBA 2930F (JL253A)
    MVP GURU
    Posted Aug 07, 2020 09:26 AM
    config t
    vlan <VLAN>
    untagged port <port>
    end
  • 3.  RE: ARUBA 2930F (JL253A)
    MVP GURU
    Posted Aug 07, 2020 09:27 AM
    or
    config t
    interface <port>
    untagged vlan <VLAN>
    end
