Wired Intelligent Edge
Aruba 2930F Tunneled Port Clearpass Roles
  • 1.  Aruba 2930F Tunneled Port Clearpass Roles
    Posted Mar 13, 2018 10:44 AM
    I´ve set up a 2930F Switch for testing port tunneling.
    The Switch has firmware WC.16.05.0004.
    The Controller has code verson 6.5.4.3 on it, for authentication I use Clearpass 6.7.
    The tunnel comes up and the authentication works fine, but the controller ignors the radius response attriubte send from clearpass.
    The controller set always its default role.
    Have anyone an idea where the problem is?
  • 2.  RE: Aruba 2930F Tunneled Port Clearpass Roles
    Posted Mar 13, 2018 10:48 AM
    Does that role exist on the controller?
  • 3.  RE: Aruba 2930F Tunneled Port Clearpass Roles
    Posted Mar 13, 2018 10:50 AM
    yes
  • 4.  RE: Aruba 2930F Tunneled Port Clearpass Roles
    Posted Mar 13, 2018 10:55 AM
    You should not be using Enforce Machine Authentication when using ClearPass. Disable that.
  • 5.  RE: Aruba 2930F Tunneled Port Clearpass Roles
    Posted Mar 13, 2018 10:59 AM
    Thanks, now it works.
  • 6.  RE: Aruba 2930F Tunneled Port Clearpass Roles
    Posted Mar 20, 2018 05:40 PM
    @Leon123, what licensing did you need to use for the tunnelled port?
  • 7.  RE: Aruba 2930F Tunneled Port Clearpass Roles
    Posted Mar 20, 2018 10:12 PM
    Per-Port consumes 1 of each controller licenses for each switch stack.
