Wired Intelligent Edge
Aruba 2930F VSF - change fault switch
  • 1.  Aruba 2930F VSF - change fault switch
    Posted Mar 12, 2018 08:33 AM
    Hello Airheads,
    I´m trying to understand if I can change a fault switch on a VSF stack without reboot the whole stack.
    For instance:
    2930F-01;
    2930F-02;
    2930F-03;
    2930F-04.
    The third switch has broken and I need to change it. Can i do that without rebooting the stack (all switches)?
    http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-a00021320en_us-2.pdf
  • 2.  RE: Aruba 2930F VSF - change fault switch
    Posted Mar 19, 2018 12:11 PM
    The added switch will reboot but not complete stack if I'm correct. If you want to keep the configuration you can clear the MAC first of the member and than replace. This will make sure new switch will get config of old. See latest management and configuration chapter 32 for different use models, procedures and commands.
    https://support.hpe.com/hpsc/doc/public/display?docId=a00038765en_us
    Regards, Dobias
  • 3.  RE: Aruba 2930F VSF - change fault switch
    Posted Mar 19, 2018 01:18 PM
    Thanks Dobias!
    Have anyone had the oppotunity to change a switch on a running stack?
