Wired Intelligent Edge
  • 1.  Aruba 2930f VSF Member Credentials
    Posted May 28, 2024 06:57 AM
    Hi!
    We are on the process of changing our local manager user credentials. All our switches are in VSF stack, if I changed the Commander local credentials, would it also change the members' credentials?
    Thank you!
    Cheers!
    Bry
  • 2.  RE: Aruba 2930f VSF Member Credentials
    Posted Jul 02, 2024 01:11 AM
    Hi folks,
    Just wanted to follow-up on this thread.
    Thank you so much, any insights wll be appreciated.
    Cheers!
    Bry
  • 3.  RE: Aruba 2930f VSF Member Credentials
    Posted Jul 02, 2024 02:04 AM
    once a switch joins the VSF stack, that switch  will have the same firmware and configuration of the VSF conductor/commander switch. So once you change the config of the commander, it will change it for all the stack members.
