Wired Intelligent Edge
Aruba 2930F with Cisco 1300 Bridge
  • 1.  Aruba 2930F with Cisco 1300 Bridge
    Posted Jun 10, 2019 12:38 PM
    We have a remote building linked with two older Cisco 1300 wireless bridges. We've replaced the older Cisco 500 switches with Aruba 2930Fs configured with data VLAN 310 and voice VLAN 311. The ports attached to the bridges are untagged VLAN 1, tagged VLAN 310, and tagged VLAN 311.  The Cisco root bridge configuration is listed below FYI but is unchanged from the original working config when we were using the Ciscos with the exception that CDP is disabled because we've had issues with Cisco WAPs registering via aruba switches when CDP is active. Traffic is not flowing between the bridges and the switches. Any help or suggestions are greatly appreciated.
    Current configuration : 1839 bytes
    version 12.3
    no service pad
    service timestamps debug datetime msec
    service timestamps log datetime msec
    service password-encryption
    hostname Redacted
    ip subnet-zero
    no aaa new-model
    dot11 vlan-name Access vlan 330
    dot11 vlan-name Cisco-Voice vlan 331
    dot11 vlan-name Native vlan 1
    dot11 ssid WCCSN
    vlan 1
    authentication open
    infrastructure-ssid
    bridge irb
    interface Dot11Radio0
    no ip address
    no ip route-cache
    ssid WCCSN
    speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
    channel 2462
    station-role root bridge
    interface Dot11Radio0.100
    encapsulation dot1Q 1 native
    no ip route-cache
    bridge-group 1
    interface Dot11Radio0.300
    encapsulation dot1Q 330
    no ip route-cache
    bridge-group 155
    interface Dot11Radio0.301
    encapsulation dot1Q 331
    no ip route-cache
    bridge-group 255
    interface FastEthernet0
    no ip address
    no ip route-cache
    hold-queue 80 in
    interface FastEthernet0.100
    no ip route-cache
    bridge-group 1
    interface FastEthernet0.300
    no ip route-cache
    bridge-group 155
    interface FastEthernet0.301
    no ip route-cache
    bridge-group 255
    interface BVI1
    ip address 192.168.199.206 255.255.255.0
    no ip route-cache
    ip default-gateway 192.168.199.1
    ip http server
    no ip http secure-server
    snmp-server community $^qaz9wsx!$ RO
    no cdp run
    control-plane
    bridge 1 protocol ieee
    bridge 1 route ip
    bridge 155 protocol ieee
    bridge 255 protocol ieee
    line con 0
    line vty 0 4
    login local
    end
  • 2.  RE: Aruba 2930F with Cisco 1300 Bridge
    MVP GURU
    Posted Jun 10, 2019 05:07 PM
    @Eric Allison wrote: We've replaced the older Cisco 500 switches with Aruba 2930Fs configured with data VLAN 310 and voice VLAN 311. The ports attached to the bridges are untagged VLAN 1, tagged VLAN 310, and tagged VLAN 311.
    Hi, can you also show us relevant configuration of those ports (on both Aruba 2930F ends) and used VLAN IDs?
  • 3.  RE: Aruba 2930F with Cisco 1300 Bridge
    Posted Jun 10, 2019 05:22 PM
    Thanks for the reply. This is one side with the relevant port being 2/24:
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1/1-1/24,2/1-2/23
    untagged 1/25-1/26,2/24-2/26
    ip address dhcp-bootp
    exit
    vlan 310
    name "VLAN310"
    untagged 1/1-1/12,1/18-1/24,2/1-2/23
    tagged 1/25,2/24-2/25
    ip address 192.168.31.3 255.255.255.0
    exit
    vlan 311
    name "VLAN311"
    tagged 1/1-1/12,1/18-1/25,2/1-2/20,2/24-2/25
    ip address 10.168.31.3 255.255.255.0
    voice
    exit
    This is the other side with the relevant port being 8:
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1-6
    untagged 8-10
    exit
    vlan 310
    name "VLAN310"
    untagged 1-7
    tagged 8
    ip address 192.168.31.4 255.255.255.0
    exit
    vlan 311
    name "VLAN311"
    tagged 1-6,8
    ip address 10.168.31.4 255.255.255.0
    voice
    exit
  • 4.  RE: Aruba 2930F with Cisco 1300 Bridge
    MVP GURU
    Posted Jun 10, 2019 05:48 PM
    Apparently both configurations (for VLAN and Interfaces tagging) look good from untagging/tagging membership standpoint...instead I noticed a good example of Cisco IOS Software Configuration Guide for Cisco Aironet 1300 Series Outdoor Access Point/Bridge 12.3(7)JA can, as example, be found here (note how at the end of the page there is "VLAN Configuration Example" which resemble your scenario...even if in your Cisco Bridge I see only one SSID)...given that it worked flawlessly when there were Cisco 500 Switches would be then interesting to see how those were configured...just to see if a 1:1 mapping between these ones and the new Aruba 2930F switches can be inferred.
    Can you also share the output of show spanning-tree (especially for port 2/24 and 8 of Aruba 2930F switches)?
  • 5.  RE: Aruba 2930F with Cisco 1300 Bridge
    Posted Jun 11, 2019 10:47 AM
    Thank You for the reference. We only need one SSID as no grouping is required. The connection supports a single office with one phone, two PCs, and a single WAP. Given my druthers, he'd move into an available office space across the road in the building that houses the root bridge, but politics.
    The 500s both connected to the bridges on ports using the Smartport "switch" setting on VLAN 1. There is no CLI on a 500 so I can't include a running config.
    This is the spanning-tree report for 2/24 on the root side:
    2/24 100/1000T | 200000 128 Forwarding | 0018ba-5ad260 2 Yes No
    The S-T report for port 8, on the other side, shows a similar entry that correctly lists the MAC address of that bridge unit.
  • 6.  RE: Aruba 2930F with Cisco 1300 Bridge
    Posted Jun 12, 2019 05:05 PM
    For the record, we had another Cisco wireless point claiming bridge root status, and confusing the spanning-tree connectiving within the dot11 realm.  I realized that after looking at dot11 association reports and seeing none on the "new" root.
    So I can now confirm that point-to-point bridging, with multiple vlans, works using the Cisco outdoor 1310 configs, and the Aruba untagged/tagged settings, listed in the posts above.
    Thank You Parnassus for the replies and references.
