Wired Intelligent Edge
aruba 2930M dhcp snooping issue clients not getting IP
  • 1.  aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 02, 2020 09:31 AM
    Hi Have been trying to get dhcp-snooping going but clients will not get an IP
    this is what I apply
    dhcp-snooping
    dhcp-snooping vlan 114
    dhcp-snooping vlan 214
    interface Trk1
    dhcp-snooping trust
    Do I have to trust the interfaces in the trunk also ?
    trunk 1/47,7/47 trk1 lacp
    Thank you
  • 2.  RE: aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 02, 2020 07:21 PM
    you know DHCP snooping is different from DHCP relay.
    are you trying to configure DHCP relay or helper address so that the clients anget IP address from the DHCP server that is not on the same VLAN?
  • 3.  RE: aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 06, 2020 11:07 AM
    Yes , I am not trying to configure DHCP relay , all our helper address are on our core , I am just trying to lock donw DHCP request from trusted up link ports,
    But When I have dhcp-snooping enabled and the truck trusted , I get no IP , Im wondering if I have to also trust the interfaces in the trunk.
    Pino
  • 4.  RE: aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 07, 2020 05:48 AM
    Trusting the trunk interface would be enough.
    Does it work when you disable snooping?
  • 5.  RE: aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 07, 2020 08:41 AM
    Yes as soon as I disable snooping dhcp works fine for clients.
  • 6.  RE: aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 07, 2020 08:52 AM
    When dhcp is active, do you see the the trk1 interface as trusted?
    is Trk1 really the correct and only uplink?
    SW01-SER# show dhcp-snooping
    DHCP Snooping Information
    DHCP Snooping : Yes
    Enabled VLANs : 1-4094
    Verify MAC address : Yes
    Option 82 untrusted policy : drop
    Option 82 insertion : Yes
    Option 82 remote-id : mac
    Store lease database : Not configured
    Rate-Limit (PPS) : 100
    Max Current Bindings
    Port Trust Bindings Static Dynamic
    1/1 No - - 1
    1/2 No - - 1
    Trk1 Yes - - -
    also please share the output of:
    show dhcp-snooping
    show dhcp-snooping stats
    show dhcp-snooping binding
  • 7.  RE: aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 09, 2020 02:50 PM
    Hi , here is what I have configured
    Duffy-Main-MDF(config)# sho dhcp-snooping
    DHCP Snooping : Yes
    Enabled VLANs : 113 123 213
    Verify MAC address : No
    Trk1 Yes - - -
    Ports
    1/1-1/46,1/48,2/1-2/48,3/1-3/48,4/1-4/48,5/1-5/48,6/1-6/48,7/1-7/48,8/1-8/46,8/
    48 are untrusted
    Duffy-Main-MDF(config)# sho dhcp-snooping stats
    Packet type Action Reason Count
    server forward from trusted port 0
    client forward to trusted port 341
    server drop received on untrusted port 0
    server drop unauthorized server 0
    client drop destination on untrusted port 0
    client drop untrusted option 82 field 0
    client drop bad DHCP release request 0
    client drop failed verify MAC check 0
    client drop failed on max-binding limit 0
    Duffy-Main-MDF(config)# sho dhcp-snooping binding
    MacAddress IP VLAN Interface Time Left
    The funny thing is I sometimes can get a laptop to work but if I plug in a IPphone or wap they do not get an ip as soon as I disable snooping they come right up.
  • 8.  RE: aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 10, 2020 03:10 PM
    Hi All, I was able to get this working , I had to disable option 82 on our stacks, I'm not sure what it does but I came across another post where it solved a similar issue, and I tried it and it worked !
    Thank you for all the help
  • 9.  RE: aruba 2930M dhcp snooping issue clients not getting IP
    Posted Jul 07, 2020 06:17 AM
    Can you see anything about DHCP packets being dropped in the switch log?
