Comware
Aruba 2930M refused to connect
  • 1.  Aruba 2930M refused to connect
    Posted Aug 13, 2024 09:40 PM
    Dear HPE support,
    I'm using Aruba 2930M switch. I have an issue that When I access ssh/telnet/web to Aruba 2930M with my IP 192.168.1.100 then return error "refused to connect." Another PC with different IP: 192.168.1.101 can access.
    I guess my computer ip address was accessed too many times, so the device locked the login
    Do you know How to remove IP that locked the login?
    Thank you.
  • 2.  RE: Aruba 2930M refused to connect
    Posted 22 days ago
    Hello oscar,
    please read the switch-manual section for "authorized managers".
    There is probably an active access-rule to only allow login from IP .101 actively. You would need to creat another allowed IP for .100.
    First check the existing reservations on the CLI with the following command:
    show authorized-managers
    or
    show running config | include authorized-manager
    To change the needed section he command should be something like this: (please modify the access-rules to your needs)
    config terminal
    ip authorized-managers 192.168.1.100 255.255.255.255 access manager
    write memory
    Afterwards please check the access-rights again with the already known command.
    Have a nice day :-)
    Franz
    prefers to not experiment with live customer equipment...
