Wired Intelligent Edge
Aruba 2930M Switch Connectivity to Internet
  • 1.  Aruba 2930M Switch Connectivity to Internet
    Posted Apr 19, 2021 12:56 PM
    We are looking for a Toplogy Design for an Internet only site where we want to use an Aruba 2930M Switch to connect to Internet/ISP for a basic Setup. Aruba Access Point (AP314) can be used for Wireless connectivity.
    What would be the best design approach to have the Switch and AP connectivity through to the Internet for different types of ISP hand-offs.
    Deepak Singh
  • 2.  RE: Aruba 2930M Switch Connectivity to Internet
    Posted Apr 26, 2021 05:58 AM
    Do you have an ISP router that can do the Network Address Translation (NAT) and DHCP? In that case, use the switch as a standard L2 device or L3 router if your ISP supports that.
    The 2930M will NOT do NAT, so you will need an (exiting) router to do that.
    Reach out to your Aruba partner for dedicated advice.
