Greetings! First post here. I have an Aruba 2930m that is directly connected to a router running pfsense. I have VLANs set up on the router properly with the correct firewall rules and have used them with other switches with no problem. I cannot for the life of me get VLANs to work on this Aruba switch. If I tag my uplink port (24) then internet connectivity goes down. I have port 21 untagged to see if VLAN30 will work with my NVR, which is set to DHCP, but it gets no IP and no connection at all. I've tried adding port 24 to a trunk, both untagged and tagged and neither works. What am I doing wrong? This seems like it's simple VLAN networking. Nothing special, just trying to separate out my network. Any help is appreciated!
Tom
