Hi community!
Do you have any information if Aruba 2xx/3xx series outdoor access points resists in an salt mine (tunnel around 5 km leight) environment. May be there is somewhere an reference case ?
Thanks you in advance!
BR,
Sergiu
I expect you would need to look at a NEMA 4x or 6p enclosure for the 2xx series as these are based on salt spray. The IP ratings do not deal with corrosion.
https://en.wikipedia.org/wiki/NEMA_enclosure_types
The AP36x for example is ASTM B117-07A: Salt spray testing per UL50 NEMA 4x as detailed in the datasheet.
https://www.arubanetworks.com/assets/ds/DS_AP360Series.pdf
