Aruba 303H RAP signal extension
  • 1.  Aruba 303H RAP signal extension
    Posted Mar 12, 2024 02:28 PM
    I have been tasked with strengthening are signal in our RAP environment. Currently, we use one RAP at each location and I was curious if there is a way to connect another 303H (wired/wirelessly) to extend signal? We are using mobility controller 7220 version 6.5.4.8., thanks.
  • 2.  RE: Aruba 303H RAP signal extension
    Posted Mar 12, 2024 10:19 PM
    While each RAP essentially operates alone, you can install more than one at a location.  But if you have need for multiple APs at a remote site you should be looking at IAP, specifically IAP-VPN.
    Carson Hulcher, ACEX#110
