Aruba 3200
  • 1.  Aruba 3200
    Posted Jun 06, 2013 10:41 AM
    I upgraded my 3200 from 3.3.2.13 to 5.0.3.2 and I cannot assess the web ui.  I still have telnet access.  When I login to the web ui I get this response:
    <aruba>
    <status>Error</status>
    <reason>
        Can't update a new session: 473ecb37-dfca-47f7-b4de-efab8c27c4af, Unknown column 'admin' in 'field list'
    </reason>
    </aruba>
    #3200
  • 2.  RE: Aruba 3200
    Posted Jun 06, 2013 10:50 AM
    Did you clear your browser cache?
  • 3.  RE: Aruba 3200
    Posted Jun 06, 2013 10:51 AM
    Yes sir...clear it and tried IE also.  I use Firefox
  • 4.  RE: Aruba 3200
    Posted Jun 06, 2013 10:55 AM
    Do you get that when you just browse to https://controller:4343 or after you login?
  • 5.  RE: Aruba 3200
    Posted Jun 06, 2013 10:56 AM
    Correct...I go to https://xxx.xxx.xxx.xxx:4343 I put in my login and then I get the response I added in the first post.
  • 6.  RE: Aruba 3200
    Posted Jun 06, 2013 11:02 AM
    Okay.  It is a bug from the upgrade.  It is not user serviceable, so you will have to contact support to get it fixed, unfortunately.
  • 7.  RE: Aruba 3200
    Posted Jun 06, 2013 11:08 AM
    Thanks for the help
  • 8.  RE: Aruba 3200
    Posted Jun 06, 2013 11:10 AM
    Okay.
    If you are up for some work, here is what you can do:
    Download the attached file (wms.pdf).  Copy it via TFTP to the controller's flash.  (type "dir") to make sure it is there after.
    Next, on the commandline of the controller do this:  wms import-db wms.pdf
    If it still does not work, support is your only option, unfortunately.
    Attachment(s)
    pdf
    wms.pdf   98 KB 1 version
  • 9.  RE: Aruba 3200
    Posted Jun 06, 2013 04:15 PM
    Would doing this have any effect on the client?  I need to notify first if it will have cust impact.
  • 10.  RE: Aruba 3200
    Posted Jun 06, 2013 04:19 PM
    I would wait until after hours, because it affects the WMS database which keeps track of wireless station interaction.  I don't expect clients to be kicked off when you do it, but you never know.
  • 11.  RE: Aruba 3200
    Posted Jun 06, 2013 04:21 PM
    OK, thanks for all the help.  I will try this tomorrow before contacting support.
