Aruba 3200 manual blacklist/block
  • 1.  Aruba 3200 manual blacklist/block
    Posted Nov 01, 2012 12:34 AM
    We have a Aruba 3200 controller. What i would like to do is block/ban/blacklist a devide (prob by MAC address) if i feel it is acting inappropriately. I know i can search for the device and select to blacklist it, but if the device is not currently connected then i cannot find it on the client search and therefore cannot blacklist it.
    Is there a way to manually add a MAC address so that device is blacklisted when it tries to connect? I have a list of MAC addresses id like to blacklist. Or is there a better way to blockban devices then above. I know i can do it at a firewall/UTM level but would prefer to do it at the Aruba WiFi level. Currently we are just using basic SSID with WPA security. No RADIUS, captive portal, etc.
    Thanks in advance for your help.
    #3200
  • 2.  RE: Aruba 3200 manual blacklist/block
    Posted Nov 01, 2012 06:06 AM
  • 3.  RE: Aruba 3200 manual blacklist/block
    Posted Nov 01, 2012 09:21 PM
    Thanks for the reply. I tried that and got the attached result unfortunately.
  • 4.  RE: Aruba 3200 manual blacklist/block
    Posted Nov 02, 2012 05:06 AM
    You need to be in "enable" mode to do this.  type "enable" and  then the enable password.
  • 5.  RE: Aruba 3200 manual blacklist/block
    Posted Nov 06, 2012 12:32 AM
    Great! Thanks for that.
  • 6.  RE: Aruba 3200 manual blacklist/block
    Posted Apr 15, 2014 04:56 PM
    I know this is an old thread but for those like me who do end up reading it:
    The blacklist now stays through controller reboot huzzah!
    Tested on 6.3.1.5
  • 7.  RE: Aruba 3200 manual blacklist/block
    Posted May 07, 2014 10:37 AM
    I can successfully block users from the CLI, but the problem is that i cant make them permanent blacklisted.
    Ive set the Blacklist Time within the virtual APs that is affected to zero, but what ever I do when i use show ap blacklist-clients i get 3600 sec.
    What am i doing wrong?
    Johan
  • 8.  RE: Aruba 3200 manual blacklist/block
    Posted May 07, 2014 11:00 AM
    jokohanho,
    Are you blacklisting a user that is currently connected, or no longer connected.  If the user is connected, it is the virtual AP that controls it.  If the user is NOT connected to the controller it corresponds to the "show ap blacklist-time" parameter:
    To see how long a user is not connected would be blacklisted:
    (192.168.1.3) #show ap blacklist-time
    ap blacklist-time:3600
     To change the blacklist to permanent:
    (192.168.1.3) #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (192.168.1.3) (config) #ap ap-blacklist-time ?
    <ap-blacklist-time>     time in seconds
    (192.168.1.3) (config) #ap ap-blacklist-time 0
  • 9.  RE: Aruba 3200 manual blacklist/block
    Posted May 07, 2014 11:14 AM
    Sorry, i missed to mention im trying to block mac addresses. :)
    The mac address is not connected at this point.
  • 10.  RE: Aruba 3200 manual blacklist/block
    Posted May 07, 2014 11:16 AM
    So how do I change the ap blacklist-time?
  • 11.  RE: Aruba 3200 manual blacklist/block
    Posted May 07, 2014 11:18 AM
    Sorry. I understand now. :) Thanks alot!
  • 12.  RE: Aruba 3200 manual blacklist/block
    Posted May 07, 2014 11:45 AM
    Glad you found it.  I edited my post to make it more clear and fixed a spelling error.
  • 13.  RE: Aruba 3200 manual blacklist/block
    Posted Sep 10, 2014 08:38 AM
    I black listed a client. Did a aaa user delete and stm kick-off-sta
    The device shows in the black list, but keeps connecting and passing traffic
     #show AP blacklist-clients
    Blacklisted Clients
    STA reason block-time(sec) remaining time(sec)
    34:23:87:6a:35:42 session-blacklist 60 240
    1c:3e:84:65:2e:34 session-blacklist 255 45
    20:16:d8:fb:cf:01 user-defined 635 2965
    show user-table verbose | include 20:16:d8:fb:cf:01
    10.207.4.185               20:16:d8:fb:cf:01     SSID     00:00:04
    (CNJ_.11) #show datapath session table 10.207.4.185
    Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge UsrIdx UsrVer Flags
    10.207.4.185 54.187.20.232 6 50385 80 0/0 0 96 17 tunnel 3551 10d 5dd c0b4 CI
    0/0 0 0 0 local
    10.207.4.185 54.187.20.232 6 50384 80 0/0 0 96 17 tunnel 3551 10d 5dd c0b4 CI
    0/0 0 0 0 local
    10.207.4.185 54.244.29.192 6 50369 80 0/0 0 96 19 tunnel 3551 12b 5dd c0b4 CI
    0/0 0 0 0 local
    10.207.4.185 54.244.29.192 6 50368 80 0/0 0 96 19 tunnel 3551 12b 5dd c0b4 CI
    0/0 0 0 0 local
    10.207.4.185 96.16.77.229 6 50361 80 0/0 0 96 19 tunnel 3551 132 5dd c0b4 CI
    0/0 0 0 0 local
    10.207.4.185 96.16.77.229 6 50360 80 0/0 0 96 19 tunnel 3551 132 5dd c0b4 CI
