Aruba Apps
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Aruba 3200-US Controller seems to be down
  • 1.  Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 12:09 PM
    Hello forum,
    One of our old 3200-US controllers has all of a sudden decided to stop working. All of the status lights and the network port light are green and showing no signs of disruption, however, we can no longer access the web interface, ping the unit or ssh into it. Of course this also means that none of our APs are able to communicate with it, meaning our wifi is down.I've checked the status of the port on the switch it is connected to and there doesn't seem to be any signs of the port being faulty. I just need this thing to work for another 4 months until my budget comes through to purchase a replacement wireless system. If anyone has any tips for me, I would greatly appreciate it.
  • 2.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 01:38 PM
    cirillo,
    Have you tried to hard reboot the controller? If yes, after that also, still its not responding??
    Raja
  • 3.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 01:46 PM
    Yes, we have done the hard reboot a couple of times. Unfortunately that didn’t fix anything. Thank you for the response though.
  • 4.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 03:46 PM
    what does console show ?
    maybe controller lost running config and sitting on initial config wizard... If yes, if u have any old flash/backup config, just revert the config and try...
    Raja
  • 5.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 03:50 PM
    I'm afraid I don't know how to get into the console, I have only ever accessed the controller through it's web interface. I do see that there is a serial connection on the front. If I plug into that, what program and commands would I need to access the console to see the status?
  • 6.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 04:31 PM
    cirillo,
    Connect you laptop to console/serial on controller(Serial DB9 and the RJ45).To console connection purpose and once loging in, check the show run configuration is there or not..?
    For console, use putty and make sure your station has serial drivers, and validate the com port it is using# This can be done by right clicking my computer, then go to Hardware profiles, then Device Manager. Go to the section under COM and LPT and see the com port it is using and OK..
  • 7.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 06:36 PM
    Thank you for the instructions. I was able to use putty to connect to the controller. However, when first connected, I was presented with a blank page, no text appeared. I decided to type "en" command, which then asked me what the IP address of VLan 1 was. I did so and then it wanted subnet and gateway and then went on to ask for a password. It seemed to me it was setting up the unit again. Anyhow, l answered all the questions it wanted and then it rebooted. I still cannot not ping it, ssh into it or access the web interface. Perhaps you can make out what happened. Please see the logs below.
    en
    Enter VLAN 1 interface IP address [172.16.0.254]: 172.22.120.150
    Enter VLAN 1 interface subnet mask [255.255.255.0]: 255.255.252.0
    Enter IP Default gateway [none]: 172.22.20.1
    Enter Switch Role, (master|local) [master]: admin
    Enter Switch Role, (master|local) [master]: yes
    This controller is restricted to Country code US for United States, please confi rm (yes|no)?: yes
    Enter Time Zone [PST-8:0]:
    Enter Time in UTC [21:02:08]:
    Enter Date (MM/DD/YYYY) [6/28/2016]:
    Enter Password for admin login (up to 32 chars): **********
    Re-type Password for admin login: **********
    Enter Password for enable mode (up to 15 chars): **********
    Re-type Password for enable mode: **********
    Do you wish to shutdown all the ports (yes|no)? [no]: no
    Current choices are:
    System name: en
    VLAN 1 interface IP address: 172.22.120.150
    VLAN 1 interface subnet mask: 255.255.252.0
    IP Default gateway: none
    Switch Role: master
    Time Zone: PST-8:0
    Ports shutdown: no
    If you accept the changes the switch will restart!
    Type <ctrl-P> to go back and change answer for any question
    Do you wish to accept the changes (yes|no)yes
    VLAN 1 interface IP address [172.16.0.254]: 172.22.12Creating configuration... Done.
    System will now restart!
    0.150
    System name: en
    Switch Role: master
    Time Zone: PST-8:0
    Ports shutdown: no
    Shutdown processing started
    Syncing data....done.
    en
    System name: en
    Switch Role: master
    Time Zone: PST-8:0
    Ports shutdown: no
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    1:<7>ide-disk 0.0: shutdown
    1:<0>Restarting system.
    1:.
    1:<2>Performing hard reset...
    CPBoot 1.2.0.0 (build 20527)
    Built: 2009-01-20 at 18:55:40
    DRAM: Operating at 533 MHz
    DRAM: Channel 0: 512 MB
    DRAM: Channel 2: 0 MB
    DRAM: Total = 512 MB
    POST: Memory test: Physical 0 - 0x10000000 - quick test
    Memory test: Physical 0x10000000 - 0x20000000 - quick test
    PASS
    CPU: XLR508 rev. C4 Clock: 800MHz
    Board: A3200
    CPLD: rev: 1.2
    SMP: All 8 cpus successfully started
    Boot: Primary bootflash partition
    POST2: OK
    Net: xlr_gmac0 xlr_gmac1 xlr_gmac2 xlr_gmac3
    IDE: Bus 0: OK
    Device 0: Model: CF 512MB Firm: 20080112 Ser#: 2010B 0000039205
    Type: Removable Hard Disk
    Capacity: 502.0 MB = 0.4 GB (1028160 x 512)
    Hit any key to stop autoboot: 0
    Loading image 0:0###########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
    Image is signed; verifying checksum...
    passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Booting image...
    Aruba Networks
    ArubaOS Version 5.0.1.0 (build 24398 / label #24398)
    Built by p4build@cartman on 2010-06-13 at 23:49:08 PDT (gcc version 3.4.3)
    Copyright (c) 2002-2010, Aruba Networks, Inc.
    <<<<< Welcome to Aruba Networks - Aruba A3200-US-8 >>>>>
    Performing CompactFlash fast test... Checking for file system...
    Passed.
    Reboot Cause: User reboot.
    Crash information available.
    Restoring the database...done.
    Generating SSH Keys......done.
    Initializing TPM and Certificates
    TPM and Certificate Initialization successful.
    Reading configuration from default.cfg
    Retrieving Configuration...will take approximately 1 minute
    (en)
    User: admin
    Password: **********
    (en) >show running-config
    % Invalid input detected at '^' marker.
    (en) >en
    Password:**********
    (en) #show running-config
    Building Configuration...
    version 5.0
    enable secret "******"
    hostname "en"
    clock timezone PST -8
    location "Building1.floor1"
    mms config 0
    controller config 0
    ip access-list eth validuserethacl
    permit any
    netservice svc-netbios-dgm udp 138
    netservice svc-snmp-trap udp 162
    netservice svc-syslog udp 514
    netservice svc-l2tp udp 1701
    netservice svc-ike udp 500
    netservice svc-smb-tcp tcp 445
    netservice svc-dhcp udp 67 68 alg dhcp
    netservice svc-https tcp 443
    netservice svc-pptp tcp 1723
    netservice svc-sec-papi udp 8209
    netservice svc-sccp tcp 2000
    netservice svc-http-accl tcp 88
    netservice svc-telnet tcp 23
    netservice svc-netbios-ssn tcp 139
    netservice svc-sip-tcp tcp 5060
    netservice svc-kerberos udp 88
    netservice svc-tftp udp 69
    netservice svc-http-proxy3 tcp 8888
    netservice svc-noe udp 32512
    netservice svc-cfgm-tcp tcp 8211
    netservice svc-adp udp 8200
    netservice svc-pop3 tcp 110
    netservice svc-lpd-tcp tcp 631
    netservice svc-rtsp tcp 554
    netservice svc-msrpc-tcp tcp 135 139
    netservice svc-dns udp 53 alg dns
    netservice svc-h323-udp udp 1718 1719
    netservice svc-h323-tcp tcp 1720
    netservice svc-vocera udp 5002
    netservice svc-http tcp 80
    netservice svc-http-proxy2 tcp 8080
    netservice svc-sip-udp udp 5060
    netservice svc-nterm tcp 1026 1028
    netservice svc-noe-oxo udp 5000 alg noe
    netservice svc-papi udp 8211
    netservice svc-natt udp 4500
    netservice svc-ftp tcp 21
    netservice svc-microsoft-ds tcp 445
    netservice svc-svp 119
    netservice svc-smtp tcp 25
    netservice svc-gre 47
    netservice svc-netbios-ns udp 137
    netservice svc-sips tcp 5061
    netservice svc-smb-udp udp 445
    netservice svc-cups tcp 515
    netservice svc-esp 50
    netservice svc-v6-dhcp udp 546 547
    netservice svc-snmp udp 161
    netservice svc-bootp udp 67 69
    netservice svc-msrpc-udp udp 135 139
    netservice svc-ntp udp 123
    netservice svc-icmp 1
    netservice svc-ssh tcp 22
    netservice svc-lpd-udp udp 631
    netservice svc-v6-icmp 58
    netservice svc-http-proxy1 tcp 3128
    ip access-list session control
    ip access-list session allow-diskservices
    ip access-list session validuser
    any any any permit
    ip access-list session vocera-acl
    ip access-list session icmp-acl
    ip access-list session captiveportal
    ip access-list session allowall
    ip access-list session https-acl
    ip access-list session sip-acl
    ip access-list session dns-acl
    ip access-list session tftp-acl
    ip access-list session skinny-acl
    ip access-list session srcnat
    ip access-list session vpnlogon
    ip access-list session logon-control
    ip access-list session allow-printservices
    ip access-list session cplogout
    ip access-list session http-acl
    ip access-list session dhcp-acl
    ip access-list session ap-uplink-acl
    ip access-list session noe-acl
    ip access-list session svp-acl
    ip access-list session ap-acl
    ip access-list session h323-acl
    vpn-dialer default-dialer
    ike authentication PRE-SHARE ******
    user-role ap-role
    user-role denyall
    session-acl denyall
    user-role cpbase
    session-acl cpbase
    user-role guest-logon
    user-role guest
    user-role stateful-dot1x
    user-role logon
    interface mgmt
    shutdown
    dialer group evdo_us
    init-string ATQ0V1E0
    dial-string ATDT#777
    dialer group gsm_us
    init-string AT+CGDCONT=1,"IP","ISP.CINGULAR"
    dial-string ATD*99#
    dialer group vivo_br
    init-string AT+CGDCONT=1,"IP","zap.vivo.com.br"
    dial-string ATD*99#
    interface gigabitethernet 1/0
    description "GE1/0"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/1
    description "GE1/1"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/2
    description "GE1/2"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/3
    description "GE1/3"
    trusted
    trusted vlan 1-4094
    interface vlan 1
    ip address 172.22.120.150 255.255.252.0
    ap mesh-recovery-profile cluster Recovery1FjB6lwmdzNd7NqC wpa-hexkey 0315f4a496c1f77be231662b3f25ebb8f13655e703228586a29dd7442e12ffd03b1b7c90a896fde1f121750a14ca8f31e242e137fa5b005f170664965ad0aa51d414bbee9c8a86bce0f4663a035f6b8f
    wms
    general poll-interval 60000
    general poll-retries 3
    general ap-ageout-interval 30
    general sta-ageout-interval 30
    general learn-ap disable
    general persistent-known-interfering enable
    general propagate-wired-macs enable
    general stat-update enable
    general collect-stats disable
    crypto isakmp policy 20
    encryption aes256
    crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
    crypto dynamic-map default-dynamicmap 10000
    set transform-set default-transform default-aes
    vpdn group l2tp
    ip dhcp default-pool private
    vpdn group pptp
    mux-address 0.0.0.0
    adp discovery enable
  • 8.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 07:28 PM
    I suspect, your controller configuration got corrupted..
    And next,, while you configuring the new IP address on the controller, default gateway is not set properly..
    Please cross verify the default gw once..
    Your config :-
    System name: en
    Switch Role: master
    Time Zone: PST-8:0
    Ports shutdown: no
    NOTE :- U gave subnet mask : 255.255.255.0, but while config u gave Default GW : 172.22.20.1.
    en
    Cross check it once..
    thnks,
    Raja
  • 9.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 07:35 PM
    Oops. What commands would be necessary to get back to configure the subnet? I'd like to just be able to get it back to the point where I can get into the web interface. Thank you again for your help.
  • 10.  RE: Aruba 3200-US Controller seems to be down
    Posted Jun 30, 2016 08:08 PM
    If u have backup config file with you then, we can proceed to copy the backup to controller..
    If not, try to config the controller once again..
    In your case, just change the default gateway with proper IP, hope controller will come to online.
    Ex:-   ip default-gateway 1172.22.x.x     (using console connection)..
    If not success, just reboot once, controller will get fresh config (If you hav not save the config after intial IP settings nd all.)
  • 11.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 01, 2016 01:54 PM
    I think a backup might have been created a long time ago but never copied off of the controller. If that was the case, how would I be able to find it and import it back in?
  • 12.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 01, 2016 02:52 PM
    From CLI
    SSH/Telnet to the switch from your management terminal.
    Copy the file 'flashbackup.tar.gz' to the flash on the controller using the following command:
    (Aruba) #copy tftp: <tftp-server-ip-address> flashbackup.tar.gz flash: flashbackup.tar.gz
    Run the following command:
    (Aruba) #restore flash
    Reload the switch for new files to take effect...
    If its not work / if you dont have any backup flash, try to change your controller gw and do the configuration1st onwards.
    thanks,
    Raja
  • 13.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 01, 2016 03:08 PM
    Once again, thank you for your help. I actually have a backup from another controller that I would like to use. I did backup that controller's flash using the web interface to our tftp folder. I titled it sl_aruba. However, when I run the command you suggested, I receive the following error. What did I type wrong?
    en
    Password: ********
    User: admin
    Password: ********
    User: admin
    (en) >restore flash
    (en) >copy tftp: 10.22.20.4 sl_aruba flash: sl_aruba
    (en) >copy tftp: 10.22.20.4 sl_aruba flash: flashbackup.tar.gz
    (en) >
  • 14.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 01, 2016 03:24 PM
    Be care, Dont take the backup configuration from the other controller. Because, when u copy the flash to from other controller to your controller, both controller are have same ip/gw settings, then it will be outage (If its production enviranment).
    Its better you can configure your controller as a new configuration.
    of course, you already configured the IP setting, but did only given wrong Gateway, just change it then will be come to online and go ahead with standard configure...
    thnks,
    Raja
  • 15.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 01, 2016 03:27 PM
    Once I get the IP config set properly, should I automatically be able to access the web interface or is there something else that I need to enable first? If so what might that be? I am just more comfortable configuring the controller with a gui.
  • 16.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 01, 2016 03:59 PM
    1st get it CLI using proper IP configurations, then will goto web..
  • 17.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 05, 2016 01:59 PM
    I was finally able to get the controller back online on my network. I have been trying to configure it from scratch but am having a few issues that you could perhaps help me with. The main one right now is that I have 4 SSIDs configured, including the default one that Aruaba has set up. However, when I try to connect to an AP, the only SSID that shows up as an available wireless network is the default one from aruba. None of the other ones I created are showing up. If I disable that SSID it seems to take the APs down. Any thoughts?
  • 18.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 05, 2016 02:02 PM
    Did you create those SSIDs in an AP-Group that is different from the default AP group?
  • 19.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 05, 2016 02:04 PM
    Where do I define the AP group? Keep in mind I am working in the web interface now.
  • 20.  RE: Aruba 3200-US Controller seems to be down
    Posted Jul 05, 2016 02:12 PM
    Configuration> Wizards> Campus WLAN
