Aruba 335 Access Point RAP mode problem
  • 1.  Aruba 335 Access Point RAP mode problem
    Posted Dec 07, 2018 11:44 AM
    Hi team ,
    We have 7 Remote Offices and we convert Aruba 335 in RAP mode for it.
    All Access point have wired profiles for eth-0 and th-1 ports. in eth-0 port we terminate directly internet with public ip address. IN eth-0 we terminate aruba switch 24 ports. The raps succesfuly terminate IPSEC tunnel to controllers and all users connected to switches on RAP have access to our corporate network. The wired eth-0 profil is in access mode and wired eth-1 profile is in trunk split-tunnel mode. Now Our problem is sometime (on any 2 to 3 days) our remote users is complain of loosing of internet conncetion but they have IPSEC tunnel tu our corporate resurce !!?? After Restart of Rap AP problem is soved and this is on every 2 maby 3 days . What can be a problem any of you have simmilar problem.
    Thank you !
  • 2.  RE: Aruba 335 Access Point RAP mode problem
    Posted Dec 07, 2018 01:10 PM
    You typically would need 802.11AT power for the second ethernet port to stay up.
    what is the output of:
    show ap debug system-status ap-name <name of ap> | begin "Power Status"
  • 3.  RE: Aruba 335 Access Point RAP mode problem
    Posted Dec 07, 2018 01:59 PM
    Hi Colin,
    Thank you for your replay,
    Yes we power on any of RAPs with POE+ on Ethernet -1 from switch.
    (CNSYS-WLC-1) *#show ap debug system-status ap-name RAP-Plovdiv | begin "Power Status"
    Power Status
    Item                        Value
    Power Supply                : POE-AF
    LLDP Power                  : Successfully negotiated at 25.5W
    Current Operational State   : USB port disabled  (Overridden by LLDP)
    Eth0 HW POE status          : POE AF, LLDP power: 0.0W
    Eth1 HW POE status          : POE AF, LLDP power: 25.5W
    Bandwidth Contracts Information
    Received BWM Config:
            ACL                                                            DIR  Contract-ID PerUser UseCount Rate
    cnsys-wireless-remote-users[4]                                         up   3           1       2        2000000000
    cnsys-wireless-remote-users[4]                                         down 4           1       2        2000000000
    cnsys-wireless-remote-guest-users[120]                                 up   2           1       2        2000000000
    cnsys-wireless-remote-guest-users[120]                                 down 1           1       2        2000000000
    Allocated Contracts:
    Contract-ID Rate       UseCount Available-Bytes Max-Bytes Policed-Bytes
    1           2000000000 1        62500000        62500000  0
    2           2000000000 1        62500000        62500000  0
    3           2000000000 1        62500000        62500000  0
    4           2000000000 1        62500000        62500000  0
    7           2000000000 1        62500000        62500000  0
    8           2000000000 1        62500000        62500000  0
    Power Monitoring Information
    Current(mW)  Average(mW)  Minimum(mW)  Maximum(mW)
    12070        12011        11951        12459
    Note : Avg, Min and Max power are calculated using values sampled over the previous 60 seconds
    System Status Script
    aruba_dbg_system_status Start time: Fri Dec  7 20:49:17 EET 2018
    ====== netstat -nla ======
    Active Internet connections (servers and established)
    Proto Recv-Q Send-Q Local Address                Foreign Address              State
    tcp        0      0 0.0.0.0:16385                0.0.0.0:*                    LISTEN
    tcp        0      0 :::80                        :::*                         LISTEN
    tcp        0      0 :::23                        :::*                         LISTEN
    udp        0      0 127.0.0.1:19999              0.0.0.0:*
    udp        0      0 0.0.0.0:57148                0.0.0.0:*
    udp        0      0 0.0.0.0:67                   0.0.0.0:*
    udp        0      0 0.0.0.0:3000                 0.0.0.0:*
    udp        0      0 92.247.143.178:56510         0.0.0.0:*
    udp        0      0 92.247.143.178:56511         0.0.0.0:*
    udp        0      0 :::8209                      :::*
    udp        0      0 :::8211                      :::*
    Active UNIX domain sockets (servers and established)
    Proto RefCnt Flags       Type       State         I-Node Path
    unix  2      [ ]         DGRAM                    2834   /tmp/.sock/8370.sock
    unix  2      [ ]         DGRAM                    2836   /tmp/.sock/9370.sock
    unix  2      [ ]         DGRAM                    4173   /tmp/.sock/8225.sock
    unix  2      [ ]         DGRAM                    4175   /tmp/.sock/9225.sock
    unix  6      [ ]         DGRAM                    4432   /dev/log
    unix  2      [ ]         DGRAM                    3673   /tmp/msghdlr_comm
    unix  2      [ ]         DGRAM                    3677   /tmp/.sock/8210.sock
    unix  2      [ ]         DGRAM                    4198   /tmp/.sock/8522.sock
    unix  2      [ ]         DGRAM                    4200   /tmp/.sock/9522.sock
    unix  2      [ ]         DGRAM                    4229   /tmp/.sock/15208.sock
    unix  2      [ ]         DGRAM                    4231   /tmp/.sock/16208.sock
    unix  2      [ ]         DGRAM                    4241   /tmp/.sock/8889.sock
    unix  2      [ ]         DGRAM                    4243   /tmp/.sock/9889.sock
    unix  2      [ ]         DGRAM                    4271   /tmp/.sock/8423.sock
    unix  2      [ ]         DGRAM                    4273   /tmp/.sock/9423.sock
    unix  2      [ ]         DGRAM                    4276   /tmp/.sock/8410.sock
    unix  2      [ ]         DGRAM                    4278   /tmp/.sock/9410.sock
    unix  2      [ ]         DGRAM                    4285   /tmp/.sock/8514.sock
    unix  2      [ ]         DGRAM                    4287   /tmp/.sock/9514.sock
    unix  2      [ ]         DGRAM                    3032   /tmp/.sock/8451.sock
    unix  2      [ ]         DGRAM                    3034   /tmp/.sock/9451.sock
    unix  2      [ ]         DGRAM                    3036   /tmp/.sock/8452.sock
    unix  2      [ ]         DGRAM                    3038   /tmp/.sock/9452.sock
    unix  2      [ ]         DGRAM                    3833   /tmp/.sock/8223.sock
    unix  2      [ ]         DGRAM                    3835   /tmp/.sock/9223.sock
    unix  2      [ ]         DGRAM                    5569
    unix  2      [ ]         DGRAM                    9086
    unix  2      [ ]         DGRAM                    4342
    unix  2      [ ]         DGRAM                    5913
    unix  2      [ ]         DGRAM                    6028
    /proc/net/softnet_stat:
    0000006c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0029e7f4 00000000 000002a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    cat  /proc/net/anul_ap_stats
    ANUL AP stats
    TX-txnid:0
    RX-txnid:89
    TX-Tot:156
    TX-Err:0
    RX-Tot:315
    RX-Err:0
    RX-Throttle:0
    RX-Non-80211:0
    RX-Mgmt-tot:44118
    RX-CTL:0
    RX-Data:69
    RX-Other:0
    RX-Mgmt-err:0
    RX-Mgmt-subtypes: 0:74 2:15 4:43872 10:64 11:90 12:3
    aruba_dbg_system_status Finished time: Fri Dec  7 20:49:17 EET 2018
    aruba_dbg_system_status: Read 4125 bytes in 71 lines. Truncated:FALSE
    (CNSYS-WLC-1) *#
