Aruba 3400 - allow IPSec through
  • 1.  Aruba 3400 - allow IPSec through
    Posted Jun 03, 2013 02:49 PM
    I'm new to Aruba, and i've found that on our guest network, IPSec VPNs are being blocked by the controller...I need some guidance on how to allow IPSec out to allow people on our guest network access to their home company's resources.
    Controller is Aruba 3400, software version is 6.1.3.4.  Outside internet is terminated by a Cisco ASA and firewall services are handled by the ASA (tested VPN directly out through ASA via wired LAN and it works perfectly).
    #3400
  • 2.  RE: Aruba 3400 - allow IPSec through
    Posted Jun 03, 2013 02:51 PM
    Is it allowed under the guest user-role?
  • 3.  RE: Aruba 3400 - allow IPSec through
    Posted Jun 03, 2013 02:55 PM
    I don't mean to sound like an idiot, but I'm going to anyway...where exactly should I be looking for the 'guest user role'?
  • 4.  RE: Aruba 3400 - allow IPSec through
    Posted Jun 03, 2013 03:07 PM
    Aruba allows you to apply policies to the users using user-role , each user-role has ACLs define.
    If you do show rights it would allow to see all your user-roles but if you want to see what role a certain user is getting then you can do a show user-table  | include <mac address> or <ip-address> and then this command would allow you to see what's the user-role a particular user is tie too.
    Users
    IP                          MAC                                   Name                              Role                          Age(d:h:m) Auth              AP name
    10.10.30.209    00:11:22:33:44:55  testuser@gmail.com          GUEST-ROLE              00:01:23    Web               AP-TEST
    And you can get the specifics of how that user-role is configured by using the show rights GUEST-ROLE
  • 5.  RE: Aruba 3400 - allow IPSec through
    Posted Jun 03, 2013 03:48 PM
    great stuff.  thanks.  I'm noticing on one of our other controllers that's been up for a while that there's an 'allow all' at the end of the guest policy...i'm guessing that's what needs added to allow the VPN traffic, but at the same time, I want to make sure that i'm not allowing my guest subnet to cross over into my corporate network.
    what's the best way to allow IPSec on the guest network and still maintain the integrity of my corporate wireless?
  • 6.  RE: Aruba 3400 - allow IPSec through
    Posted Jun 03, 2013 04:00 PM
    Create an access list allowing the ports needed for VPN and applied it to the user-role
    ip access-list session GUEST-VPN-ACL
    any any svc-ike
    any any svc-esp
    any any svc-l2tp
    any any svc-pptp
    any any svc-gre
    user any svc-natt
    You can configure it this way if you are nating under the VLAN ,if not you have to apply your source nating for each rule
    user-role GUEST-ROLE
    access-list session GUEST-VPN-ACL position "based on how you have your ACL configured"
  • 7.  RE: Aruba 3400 - allow IPSec through
    Posted Jun 03, 2013 04:17 PM
    Great stuff.  Appreciate the help!
