Aruba 3400 and Vlan tagging
  • 1.  Aruba 3400 and Vlan tagging
    Posted Mar 16, 2017 09:39 AM
    Hi, I am using a 3400 controller and I would like to configure a trunk link between the 3400 and a Cisco switch.
    An SSID is tunneled and assigned with a specific vlan and when I configure an access port between the 3400 and the Cisco , my laptop recieved an IP from a remote DHCP.
    When both interfaces are configured as trunk with the same configuration I didn't recieve any IP and no trace of mac address on cisco switch.
    My configuration are , vlan 81 is the vlan, even as native vlan it doesn't work
    interface gigabitethernet 1/1
    description "GE1/1"
    trusted
    trusted vlan 80-81
    switchport mode trunk
    switchport trunk native vlan 80
    switchport trunk allowed vlan 80-81
    no spanning-tree
    interface Ethernet1/1/6
    description FR-DC1-CTL-01_GE1/1
    switchport trunk allowed vlan 81
    As access port on both side it works, so I have no more idea to fix it
    Regards
  • 2.  RE: Aruba 3400 and Vlan tagging
    Posted Mar 16, 2017 09:44 AM
    Did you set your Cisco Trunk port to dot1q for its trunk encapsulation? .
  • 3.  RE: Aruba 3400 and Vlan tagging
    Posted Mar 16, 2017 09:45 AM
    Do you have switchport mode trunk on the cisco interface?
  • 4.  RE: Aruba 3400 and Vlan tagging
    Posted Mar 17, 2017 05:29 AM
    About the switchport  mode trunk I did it but as I didn't understand the behavior I reloaded the switch and now the vlan is working well, but maybe with all tests I performed the switch was in unstable state.
    So sorry and thanks for your reply.
