Aruba 3400 Cannot ping after installing licenses
  • 1.  Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 07:25 AM
    We have a 3400 controller and when we install a license on the controller it stops working you cant ping it or access it via the web gui.
    Any ideas?
    #3400
  • 2.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 07:32 AM
    Is the port trusted?   From the console:
    show port status
    if your port shows untrusted:
    config t
    interface gigabitethernet 1/X <your port number>
    trusted
    wr mem
  • 3.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 08:57 AM
    I will test this now.
    Is this an known issue?
    thanks
  • 4.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 09:10 AM
    the ports are trusted, and its when we are trying to add a pefng license
  • 5.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 10:34 AM
    When you add the PEFNG license, who cannot ping or access the controller; wireless or wired users?  Do you have any firewall policies on the ports?
    show ip access-group
  • 6.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 10:41 AM
    it is a wired user that is trying ping and add the license also it doesnt ping on the wireless.
  • 7.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 10:49 AM
    Hi Sorry,
    The Controller doesnt physically accept the license we cannot add it then it cant ping or access it from the webui either. Put we can if we serial onto it.
  • 8.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 10:56 AM
    If you do a show log system 50 and show log network do you see anything there?
    And like clembo mentioned you should try looking in your interface to see if there a ip access-group attached to the interface if you have an access list that deny certain things is going to block every incoming traffic (Wireless or Wired)
    If you do a show  running-config  | begin interface and then look for the interface going to uplink switch
  • 9.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 11:25 AM
    So, you try to add the license, it rejects it; then the controller is unresponsive to pings or WebUI?
    Does the controller give an error when you add the license?
    Make sure there is no trailing blank space after the license activation key when you add it.
    Are you adding from the WebUI or the CLI?  Try the opposite.
  • 10.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 21, 2013 11:30 AM
    Yes that is correct we just add it via both the console and the webui.
    We are trying to rebuild the controller and add it again. We will give you method a try now for you
  • 11.  RE: Aruba 3400 Cannot ping after installing licenses
    Posted May 22, 2013 03:48 PM
    can you run the following command show log errorlog all and see if anything interesting comes up
