Wired Intelligent Edge
Aruba 3810 & 2540 - LACP configuration
  • 1.  Aruba 3810 & 2540 - LACP configuration
    Posted Jan 07, 2019 01:31 AM
    I wanted to implement LACP for a client.
    I have two core switches aruba 3810 and for distribution switches aruba 2540.
    Can you guys help how to configure LACP.
    I also wanted to know if there's any software simulator like packet tracer for aruba switches.
    Thanks in advance.
  • 2.  RE: Aruba 3810 & 2540 - LACP configuration
    Posted Jan 07, 2019 09:32 AM
    For LACP you need to create a trunk:
    Command:
    trunk 21,22 trk1 lacp
    For port 21 and 22
    For provision (ArubaOS-switch) there is no simulator, for ArubaOS-CX there is.
  • 3.  RE: Aruba 3810 & 2540 - LACP configuration
    Posted Jan 08, 2019 12:45 AM
    So configurations are made only on the core switch.
  • 4.  RE: Aruba 3810 & 2540 - LACP configuration
    Posted Jan 08, 2019 02:25 AM
    Lacp needs to be configured on both sides.
    As you have 2 ArubaOS-Switch the command is equal to both switches.
    Did you configure the core as a stack?
    Can you share your overall design? Because only implement LACP is not enough.
  • 5.  RE: Aruba 3810 & 2540 - LACP configuration
    Posted Jan 08, 2019 02:51 AM
    Yes it's configured as stack.
    Here's a brief setup ( find image)
  • 6.  RE: Aruba 3810 & 2540 - LACP configuration
    MVP GURU
    Posted Jan 08, 2019 09:03 AM
    Cisco Catalyst style...where are Arubas?
  • 7.  RE: Aruba 3810 & 2540 - LACP configuration
    Posted Jan 08, 2019 11:42 AM
    Hi Parnassus,
    I was asked for a design, I used packet tracer just to give a quick description.
