Hi Dik,
Thanks for your answer.
I read a document somewhere that told 3810M uses CAM to store ACEs instead of TCAM.
As far as I know, CAM and TCAM are different types of memory, but basically, they are hadware based. In fact, some of the models that you mentioned use TCAM and other models use CAM to implement ACLs and QoS.
Can you confirm that 3810M uses CAM to implement ACLs and QoS in hardware?
Kind regards
