Network Management
Aruba 3810M issue putting a interface on trunk or access vlan 50
  • 1.  Aruba 3810M issue putting a interface on trunk or access vlan 50
    Posted Feb 12, 2019 05:19 PM
    I am replacing a Cisco 3750 with a Aruba 3810M. I cannot figure out how to do a switchport access vlan 50 or how to do a switchport mode trunk on a port.
    What I do now is
    Config t
    Interface ethernet 1
    (eth1)# switchport access vlan 50
    or
    (eth1)# switchport mode trunk
    Invalid input: switchport    <--- Issue wont take command
    Any help would be appreciated.
  • 2.  RE: Aruba 3810M issue putting a interface on trunk or access vlan 50
    Posted Feb 12, 2019 05:50 PM
    HPE uses tagged and untagged for VLANs..
    ==================Access Port==============
    For Cisco:
    interface gi 0/0
    switchport mode access
    switchport access vlan 90
    For 3810 (assuming eth0/0 is an access port):
    vlan 90
    untagged eth0/0
    ==================Turnk Port==============
    For Cisco
    inter eth 1
    on 3810 (assuming eth 1 is the trunk link):
    vlan 90
    tagged eth1
    vlan 91
    tagged eth1
  • 3.  RE: Aruba 3810M issue putting a interface on trunk or access vlan 50
    MVP EXPERT
    Posted Feb 12, 2019 06:22 PM
    Hi Lionelgalvan1,
    Here you find the CLI Reference Guide for ArubaOS-CX, ArubaOS-Switch and Cisco IOS
    Excellent document that will help you for sure!
    https://support.hpe.com/hpsc/doc/public/display?docId=c04793912
  • 4.  RE: Aruba 3810M issue putting a interface on trunk or access vlan 50
    MVP GURU
    Posted Feb 13, 2019 09:41 AM
