Wired Intelligent Edge
Aruba 3810M (JL075A) support JL085A + JL087A power supply together
  • 1.  Aruba 3810M (JL075A) support JL085A + JL087A power supply together
    Posted Apr 24, 2024 12:42 PM
    Hello, I'm inquiring about the possibility of utilizing both power supplies simultaneously on the Aruba 3810M
  • 2.  RE: Aruba 3810M (JL075A) support JL085A + JL087A power supply together
    Posted Apr 24, 2024 01:56 PM
    No that won't work:
    Aruba 250W Power Supply, (JL085A, Aruba X371 250W 100-240VAC to 12VDC PS) is used with the non-
    PoE switches and is keyed so that it cannot be used in the PoE/PoE+ switches.
    • Aruba 680W PoE+ Power Supply, (JL086A, Aruba X372 680W 100-240VAC to 54VDC PS) used with the
    PoE/PoE+ switches and is keyed so that it cannot be used in the non-PoE switches.
    • Aruba 1050W PoE+ Power Supply, (JL087A, Aruba X372 1050W 100-240VAC to 54VDC PS) is used with
    the PoE/PoE+ switches and is keyed so that it cannot be used in the non-PoE switches
  • 3.  RE: Aruba 3810M (JL075A) support JL085A + JL087A power supply together
    MVP GURU
    Posted Apr 24, 2024 01:59 PM
    Exactly, since the Aruba 3810M with SKU JL075A is a non PoE model, it accepts only non PoE keyed Power Supply Unit(s), a single JL085A unit or a pair of JL085A units.
