Wired Intelligent Edge
last person joined: 9 hours ago
Aruba 3810M (JL076A) support JL085A power supply
  • 1.  Aruba 3810M (JL076A) support JL085A power supply
    Posted Jan 15, 2018 04:10 PM
    Hey Airheads. I was wondering if you guys knew if a JL085A power supply will work in a Aruba 3810M (JL076A)?
    The data sheet here (p11) says the (JL076A) Must have JL086A or JL087A power supply. Do you know if it would even bootup with a JL085A power supply instead?
  • 2.  RE: Aruba 3810M (JL076A) support JL085A power supply
    Posted Jan 16, 2018 02:42 AM
    Hi Sean,
    This will not work. All the POE power supplies are keyed to not fit in non POE switches and vica versa.
    Let me know if this answer helps you and if you have any other questions.
    Regards, Dobias
  • 3.  RE: Aruba 3810M (JL076A) support JL085A power supply
    Posted Jan 16, 2018 09:23 AM
    Thanks man! I figured. But its ok, I just ordered two JL086A power supplies. Those will work :-)
  • 4.  RE: Aruba 3810M (JL076A) support JL085A power supply
    Posted Jan 16, 2018 09:24 AM
    You're welcome!
    Met vriendelijke groet / Kind regards,
    [ruba-hp-signature-2_160x105.jpg]
    Dobias van Ingen
    EMEA CTO and SE Director
    UC & C: + 31202450591 | M: +31 651 785440 | @networkingdvi
    Startbaan 16 | 1187 XR Amstelveen | Netherlands
    WWW.ARUBANETWORKS.COM<> | FOLLOW US | Twitter<> | LinkedIn<>
  • 5.  RE: Aruba 3810M (JL076A) support JL085A power supply
    Posted Jan 16, 2018 02:50 AM
    it will not work base on the configurator
  • 6.  RE: Aruba 3810M (JL076A) support JL085A power supply
    Posted Jan 16, 2018 09:21 AM
    Thank you
