Wired Intelligent Edge
Aruba 3810m - Reset to defaults?
  • 1.  Aruba 3810m - Reset to defaults?
    Posted Jul 25, 2018 08:21 AM
    We are just beginning to use Aruba Network gear. I was testing a switch to learn how to configure them. I left it alone for about a week and have forgotten the login information that it was cofigured with. Is there a process to reset the switch to defaults, or a password recovery process?
  • 2.  RE: Aruba 3810m - Reset to defaults?
    Posted Jul 25, 2018 08:33 AM
  • 3.  RE: Aruba 3810m - Reset to defaults?
    Posted Jul 25, 2018 09:40 AM
    This works well
    erase all
  • 4.  RE: Aruba 3810m - Reset to defaults?
    Posted Jul 25, 2018 09:55 AM
    Yes that is correct, my main obstacle was getting past the login, since that was forgotten.
    Pressing the clear button twice for 5 seconds, cleared the logins. Then I was able to do an Erase All to clear the config.
    Thank you for your reply!
