Wired Intelligent Edge
last person joined: 7 hours ago
Aruba 3810M Wired Guest
  • 1.  Aruba 3810M Wired Guest
    Posted Apr 29, 2017 10:31 PM
    Hi Folks. I am trying to do wired guest with ClearPass and Aruba 3810M access switches.  I have two services on CPPM to accomplish this:
    1. First service is Allow All MAC AUTH. If EndPoint is Unknown, it returns dynamic ACL along hpe-captive-portal-url attribute to the switch. If endpoint is know, an unrestricted profile is sent to the switch.
    2. Second service is Web-auth to authenticate the captive portal user.
    Everything seems to be working as aticipated. If an unknown endpoint comes on the network, I can see radius ACL assinged on the port (show access-list radius port id) and captive portal URL receied by the switch (show port-access clients detailed). Somehow, client is not being automatically redirected to the captive portal page. End to end flow works fine if I manually type the registration page URL and register/login.
    I do have L3 interface on guest VLAN creatd on the switch. Running out of options to troubleshoot this issue further. Any help would be appreciated.
    I also have a TAC case opened, but havent progressed bit in last 4 days unfortunately.
  • 2.  RE: Aruba 3810M Wired Guest
    Posted Apr 29, 2017 11:49 PM
    What version of ArubaOS-Switch?
  • 3.  RE: Aruba 3810M Wired Guest
    Posted Apr 30, 2017 12:14 AM
    Was running on 16.03.0003 & yesterday upgraded to 16.03.0004. both have similar behavior.
  • 4.  RE: Aruba 3810M Wired Guest
    Posted Apr 30, 2017 11:57 AM
    Please post screenshots of your enforcement profile(s).
  • 5.  RE: Aruba 3810M Wired Guest
    Posted Apr 30, 2017 07:32 PM
    Hi Tim,
    Please find below:
    Also, I can vertify correct attributes sent back to the switch:
    And the switch config is pretty simple:
    l3swaccstack# sh ip  | inc 153
      Wi-Fi_Guest04        | Manual     172.25.153.200  255.255.255.0    No    No
    l3swaccstack#
    radius-server host 172.25.16.4 key "xxxx"
    radius-server host 172.25.16.4 dyn-authorization
    radius-server host 172.25.16.4 time-window 0
    aaa authentication port-access chap-radius
    aaa port-access mac-based 1/48
    aaa authentication captive-portal enable
    where 172.25.16.4 is CPPM VIP.
  • 6.  RE: Aruba 3810M Wired Guest
    Posted Apr 30, 2017 07:36 PM
    Hi Tim,
    For some reason I am unable to add the screenshots inline. I have atttached them.
    The switch config is pretty simple:
    radius-server host 172.25.16.4 key "xxxxx"
    l3swaccstack#
    l3swaccstack#
  • 7.  RE: Aruba 3810M Wired Guest
    Posted May 01, 2017 08:50 AM
    You need the following two entries to trigger the redirect:
    Radius:IETF	NAS-Filter-Rule	=	deny in tcp from any to any 80 cpy
    Radius:IETF	NAS-Filter-Rule	=	deny in tcp from any to any 443 cpy
    Also, you may want to consider using user-roles instead. Much easier.
  • 8.  RE: Aruba 3810M Wired Guest
    Posted May 01, 2017 07:07 PM
    Hi Tim,
    Thanks. I am out of site for couple of days. Will check and update you.
  • 9.  RE: Aruba 3810M Wired Guest
    Posted May 10, 2017 06:22 PM
    Hi Tim. Adding these statements made it work. Thanks..
    #AirheadsMobile
