Aruba 501 Bridge
  • 1.  Aruba 501 Bridge
    Posted Feb 07, 2019 03:06 PM
    Hey guys do you know if you can manage the 501 bridges with Airwave? I have about 80 to upgrade and setup. Is there an easier process to do this?
  • 2.  RE: Aruba 501 Bridge
    Posted Feb 07, 2019 04:00 PM
    Airwave supports image and config push via SNMP on the 501 bridges; it does not support monitoring.
  • 3.  RE: Aruba 501 Bridge
    Posted Feb 07, 2019 04:49 PM
    Thank you @onno :-).
