Aruba 5.0.4.10 compatibility
  • 1.  Aruba 5.0.4.10 compatibility
    Posted Apr 13, 2013 03:27 PM
    Hi Aruba Community,
    Does anyone know if AP 60 series support 5.0.4.10? And What about controller A3200?
    Tnak you all
  • 2.  RE: Aruba 5.0.4.10 compatibility
    Posted Apr 13, 2013 07:02 PM
    yes the ap 60 should support that firmware with no issue... in fact i used to have a client with ap 61  with AOS 3.x.x... i had to upgrade that conroller to 6.1.3.6 a few months ago
    And yes the Aruba 3200 should be able to support that firmware... in fact i had to do a downgrade to a Aruba 650 from 6.1.3.5 to 5.0.3.3 becasue the client had his master on that firmware and they are afraid to upgrade it  :)  so they made me downgrade the 650...
    Cheers
    Carlos
  • 3.  RE: Aruba 5.0.4.10 compatibility
    Posted Apr 13, 2013 07:10 PM
    Thank you man.
    Do you know where can i find release notes of each firmware? and does any matrix of supported feature and equipement exists?
    Thank you again.
  • 4.  RE: Aruba 5.0.4.10 compatibility
    Posted Apr 13, 2013 07:14 PM
    yes i know its on the partner center :) but you are not a partner yet...
    I wish i could give you the release notes and i would if i could but our region latin america is running through a maintenience and i got no access to firmwares downloads(which means also the release notes i cannot see them)
    I have to wait until next week before having access :( otherwise i would post them for you.  Maybe some other forum user can colaborare with you and share them i mean one of another region which actually got access to those files...
    Cheers
    Carlos
  • 5.  RE: Aruba 5.0.4.10 compatibility
    Posted Apr 13, 2013 07:17 PM
    @Zakaria wrote:
    Thank you man.
    Thank you again.
    Please try here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/Default.aspx
  • 6.  RE: Aruba 5.0.4.10 compatibility
    Posted Apr 13, 2013 07:20 PM
    Hi
    I know this site. I don't find the release note for this firmware.
    Thank you
  • 7.  RE: Aruba 5.0.4.10 compatibility
    Posted Apr 14, 2013 02:15 PM
    :smileyhappy:
    Here:
    U may download it from my DropBox
    https://www.dropbox.com/s/zbu0v5oy43ccyu5/ArubaOS%205.0.4.10%20Release%20Notes.pdf
    Enjoy. :smileywink:
    Me.
  • 8.  RE: Aruba 5.0.4.10 compatibility
    Posted Apr 15, 2013 03:17 AM
    Thank you man
