Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
Aruba 505 Unified AP and AP-207
  • 1.  Aruba 505 Unified AP and AP-207
    Posted 17 days ago
    Dear Sir,
    Good Day.
    We have one Access Point Aruba 505 Unified AP  (R2H25A) working as Virtual Controller. and another access point AP-207 (JX952A).
    Access point 207 does not appear in the virtual controller dashboard and both of them are in the same subnet.
    can you support fixing this issue, please?
    thanks in advance
  • 2.  RE: Aruba 505 Unified AP and AP-207
    Posted 16 days ago
    is this a new deployment and do both the APs have the same firmware version?
  • 3.  RE: Aruba 505 Unified AP and AP-207
    Posted 16 days ago
    Hi Sir.
    yes. this is a new deployment. and APs diffrent firmware.
    How can I upgrade AP-207 Firmware (JX952A) as the AP make restart every 5 min ( i think because can't find the controller )?
    Regrds.
  • 4.  RE: Aruba 505 Unified AP and AP-207
    Posted 16 days ago
    connect the AP-207 to an isolated VLAN, separate from the other APs,
    then through the webUI upgrade it to the same version of your other APs.
    after that, you can add AP-207 to the same VLAN as the other APs and it will join the cluster.
    you can download the firmware from ASP
  • 5.  RE: Aruba 505 Unified AP and AP-207
    Posted 16 days ago
    as my information AP-207  (JX952A) , without WebUI.  The last firmware I found in ASP  Oct 2017
    https://asp.arubanetworks.com/downloads;search=JX952A;products=Aruba%20Access%20Points
    How can i fix this issue ?
    Thanks in advance
  • 6.  RE: Aruba 505 Unified AP and AP-207
    Posted 16 days ago
    oh AP-207  (JX952A) is not Instant AP and can not join an Instant AP cluster.
    for AP-207  (JX952A), you need an Aruba controller.
