Aruba 515s not showing up in Virtual Controller
  • 1.  Aruba 515s not showing up in Virtual Controller
    Posted Sep 24, 2019 08:10 PM
    I have a Virtual Controller with 8.4.0.4. And the two 515 access points I have will not show up as active access points. They do show up as allowed-ap under configuration.
    The rest of the access points in the VC are 325s (20 Total).
    Any suggestions on how I can get them to show up as active access points? And bring the total up to 22?
    Thank you,
  • 2.  RE: Aruba 515s not showing up in Virtual Controller
    Posted Sep 24, 2019 09:34 PM
    Are the 515s running 8.4.0.4 code?
  • 3.  RE: Aruba 515s not showing up in Virtual Controller
    Posted Sep 25, 2019 01:55 PM
    Updated them to the same code and they are now showing up.
    Thank you,
  • 4.  RE: Aruba 515s not showing up in Virtual Controller
    Posted Sep 25, 2019 01:59 AM
    What is the output of "show ap database | include <ip of ap>".
    Do you have sufficient licenses ?
    An MM license along with an AP license is consumed.
    What is seen in " show license-usage ap ".
    What do the console output indicate? Is this AP abke to discover the master and receive an IP.?
  • 5.  RE: Aruba 515s not showing up in Virtual Controller
    Posted Sep 26, 2019 06:13 AM
    Hi Ajay,
    It is an instant installation, so no licences needed.
  • 6.  RE: Aruba 515s not showing up in Virtual Controller
    Posted Oct 02, 2019 07:41 AM
    Need Firmware 8.5 to support the 500 series access points.
