Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
Aruba 535 AP not using correct cert for WebUI
  • 1.  Aruba 535 AP not using correct cert for WebUI
    Posted Apr 28, 2023 10:06 AM
    Hi All,
    I uploaded a new cert for an Aruba 535 and marked it as "WebUI", but when I look at the Certificates, the Aruba default cert is still showing as the "Default Server Cert" and when I log into the WebUI, the cert I uploaded isn't being presented.  I don't see a way in the GUI to change this, it only gives me an option to upload a new cert, and add an entry into the Certificate Usage table.
    Is there a trick to this?
    Joel
  • 2.  RE: Aruba 535 AP not using correct cert for WebUI
    Posted Apr 28, 2023 11:35 AM
    You can configure the Web UI certificate under Maintenance -> Certifiates -> Certificate Usage:
    Press the + to configure certificates for the different purposes.
  • 3.  RE: Aruba 535 AP not using correct cert for WebUI
    Posted Apr 28, 2023 11:53 AM
    Hi Robert,
    Thanks for the reply.  That is what I've done, but when I go to the web address, that's not the cert that's being used.
    In the Certificates, I see that the "Current Web UI Server Certificate" is the one I uploaded, but when I go to the site.  I've included images of the WebUI Cert the AP tells me it's using vs what I actually see when I login to the WebUI
    Screencap of current WebUI Cert
    The cert I'm presented when logging into WEBUI
  • 4.  RE: Aruba 535 AP not using correct cert for WebUI
    Posted Apr 30, 2023 01:30 AM
    see if a reboot will show it correctly.
    Any opinions expressed here are solely my own and not necessarily that of HPE or Aruba.If my post was useful accept solution and/or give kudos.
  • 5.  RE: Aruba 535 AP not using correct cert for WebUI
    Posted May 02, 2023 02:56 PM
    A reboot did not resolve this
    Joel Doetsch
  • 6.  RE: Aruba 535 AP not using correct cert for WebUI
    Posted 15 days ago
    Hi Joel,
    You can try to remove the cert and add and assign again as Herman told you.
    In order to remove the cert, you need use the next command:
    crypto pki-remove cert-type ServerCert certname <name of your cert>
    I hope this helps
