Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
  • 1.  Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 23, 2020 01:59 PM
    I hope someone can help me as I have an entire floor of a building with no wireless right now.
    Brand new 535s connect to the controller but interface up/down every so many minutes. LLDP shows nothing but very basic information. APs show 15.4W pull on power. They don't seem to allow clients on. I've tried a bunch of things, but I don't want to muddy the troubleshooting process in case I botched something. Please Help!
  • 2.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 23, 2020 02:44 PM
    What is the output of "show lldp" on the Cisco switch?
  • 3.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 23, 2020 06:03 PM
    please dont use vlan 1 for management for cisco switchs and all switch just use rstp.
    Please try and you give me information
  • 4.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 23, 2020 08:09 PM
    They’re connected to a Cisco 3850-48U switch. There’s two separate switch stacks that several APs are connected to. In one switch, we’ve got some APs that are functional (this just happened with no interference on my part after I posted). Those APs look similar to this when you do a show lldp neighbor detail.
    Chassis id: 004e.35c4.d508
    Port id: 004e.35c4.d508
    Port Description: eth0
    System Name: HSS-4123
    System Description:
    ArubaOS (MODEL: 535), Version Aruba AP
    Time remaining: 96 seconds
    System Capabilities: B,W
    Enabled Capabilities: W
    Management Addresses:
        IP: 10.20.0.20
    Auto Negotiation - supported, enabled
    Physical media capabilities:
        1000baseT(FD)
        Asym Pause(FD)
        Pause(FD)
        100base-TX(FD)
        Other/unknown
    Media Attachment Unit type: 30
    Vlan ID: - not advertised
    PoE+ Power-via-MDI TLV:
    Power Pair: Signal
    Power Class: Class 4
    Power Device Type: Type 2 PD
    Power Source: PSE
    Power Priority: unknown
    Power Requested: 25500 mW
    Power Allocated: 25500 mW
    MED Information:
        MED Codes:
              (NP) Network Policy, (LI) Location Identification
              (PS) Power Source Entity, (PD) Power Device
              (IN) Inventory
        H/W revision: 02.03
        F/W revision: 2.4.1.21 (69326)
        S/W revision: Aruba AP
        Serial number: CNHQK9W22W
        Manufacturer: Aruba Networks
        Model: 535
        Capabilities: NP, IN
        Device type: Network connectivity
        Network Policy(Voice): VLAN 0, untagged, Layer-2 priority: 0, DSCP: 0
        Power requirements - not advertised
        Location - not advertised
    There are other APs on this same switch that look like this:
    Chassis id: 004e.35c4.d898
    Port id: 004e.35c4.d898
    System Name - not advertised
    System Description:
    Time remaining: 0 seconds
    Enabled Capabilities - not advertised
    Management Addresses - not advertised
    Auto Negotiation - not supported
    Physical media capabilities - not advertised
    Media Attachment Unit type - not advertised
    All APs get IP addresses and have been provisioned by the controller/Mobile Manager. The ones that have the first LLDP information function. The ones with the shorter LLDP information does not. The other switch stack has no functional APs on it. The one with some functional APs is running 03.06.00E code, the other one, we just upgraded to 16.12.3a.
  • 5.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 23, 2020 07:23 PM
    Are these brand new like out of the box? I ran into what sounds like the same issue with 535s out of the box on Cisco switches, for whatever reason they could NOT get DHCP IP addresses, thus the reboot loops. I had to take them back down, plug them to a different switch, they started working, got updated code from our controller, then I could move them back to the original switches again. So there is some compatibility issues with some versions of the 535s and Cisco hardware/software. In my case also happens on some 2960-Xs. So my suggestion would be try them on a different switch hardware/software combo until you get them to work, and hopefully whatever controller software you are running won't have the same problem. Otherwise you might have to start playing with Cisco IOS versions to find the right mix.
  • 6.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 23, 2020 08:10 PM
    Out of the box. They get IPs, they upgraded themselves, they have been provisioned by Mobile Manager, they show that they should be working, but don't and reset the interface every 5 to 8 minutes or so.
  • 7.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 23, 2020 08:25 PM
    Great so now some are working and some aren't for no apparent reason? I love those issues.
    What code version? We were probably on 8.5.0.4 or 8.5.0.6 when we rolled those out and as soon as they upgraded they started working. Out of the box they were probably on 8.5.0.0.
  • 8.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 23, 2020 08:44 PM
    Yep. On the non-upgraded switch I have 6 out of 9 working. On the upgraded switch 0 of 9. I did nothing to make the six work. I don't have access to the code number right now, but it's relatively new
  • 9.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 27, 2020 01:21 AM
    Aruba AP-555 (8.7.0) running on Cisco 2960L (15.2(6)E2b, LACP with 2 ports and 2x PoE+ (802.3at)):
    interface Port-channel1
    description to Aruba-555
    no keepalive
    interface GigabitEthernet0/1
    description to Aruba AP-555
    power inline static
    no keepalive
    channel-group 1 mode active
    interface GigabitEthernet0/2
    power inline static
    no keepalive
  • 10.  RE: Aruba 535s not functioning with Cisco 3850 switch (03.06.00E)
    Posted Jul 27, 2020 10:53 AM
    Sorry folks. In the years that I've worked in IT, I've learned that coincidence almost never exists. I got bit by it this time.
    We've been rolling out new APs. This error started just as we started a new building populated with switches that we've never connected Aruba APs to. What are the odds, right? The Mobile Manager didn't have any warnings for this issue and so it just appeared to be a LLDP discovery problem.
    It wasn't. It was a licensing issue. Either my predecessor had forgotten to install the licenses, or the emails got lost in the shuffle of me taking over.
    Sorry for the false alarm. Thanks for all of the assistance.
