Wired Intelligent Edge
Aruba 5400 switch PSU temperature sensor
  • 1.  Aruba 5400 switch PSU temperature sensor
    Posted Apr 23, 2020 06:33 AM
    I have several Aruba 5406R-zl2's in production that from time to time have error messages as those below:
    M 04/23/20 11:35:42 02794 chassis: AM1: Internal power supply 2: PoE power exceeds the temperature threshold value. Power supply faulted. Total fault count: 0
    M 04/23/20 11:35:42 02798 chassis: AM1: Internal power supply 2 main PoE power faulted. Total fault count: 1
    M 04/23/20 11:36:42 02794 chassis: AM1: Internal power supply 2: PoE power within the temperature threshold value. Power supply OK. Total fault count: 1
    M 04/23/20 11:36:42 02798 chassis: AM1: Internal power supply 2 main PoE power OK. Total fault count: 1
    The error I have a question about is it exceeds the temperature threshold value. However, I seem to be unable to find other temperature commands in the switch than the general command:
    switch1# show system temperature
    System Air Temperature
    Temp Current Max Min
    Sensor Temp Temp Temp Threshold OverTemp
    Chassis 23C 26C 20C 55C NO
    Is there a command to see the temperature of the PSU's? What are their threshholds set at? The switch has 2 x J9829A PSU's and the power consumption is rather low compared to the 1100 W they can deliver.
    switch1# show system power-consumption
    Slot Power Usage:
    Slot Module Description Current Power
    A HP J9538A 8p 10G-GbE SFP+ v2 zl Module 32 W
    E HP J9538A 8p 10G-GbE SFP+ v2 zl Module 30 W
    F HP J9538A 8p 10G-GbE SFP+ v2 zl Module 31 W
  • 2.  RE: Aruba 5400 switch PSU temperature sensor
    MVP GURU
    Posted Apr 23, 2020 10:23 AM
    Hi!
    Try with the show system power-supply detailed CLI command.
    The output should be similar to:
    5412Rzl2# show system power-supply detailed
     Status and Counters - Power Supply Detailed Information
      PS Model  Serial     State            Status
      1  J9829A CN6AK36XXX Powered          AC Power Consumption : 81 Watts
                                            AC MAIN Voltage      : 229 Volts
                                            Power Supplied       : 63 Watts
                                            Power Capacity       : 1100 Watts
                                            Inlet Temp (C/F)     : 32.8C/89.6F
                                            Internal Temp (C/F)  : 50.6C/122.0F
                                            Fan 1 Speed          : 1125 RPM (33%)
                                            Fan 2 Speed          : 1125 RPM (33%)
      2  J9829A CN6AK36XXX Powered          AC Power Consumption : 84 Watts
                                            Power Supplied       : 64 Watts
                                            Inlet Temp (C/F)     : 30.1C/86.0F
                                            Internal Temp (C/F)  : 46.9C/114.8F
                                            Fan 1 Speed          : 1110 RPM (32%)
                                            Fan 2 Speed          : 1095 RPM (32%)
      3  J9829A CN6AK36XXX Powered          AC Power Consumption : 82 Watts
                                            Inlet Temp (C/F)     : 31.3C/87.8F
                                            Internal Temp (C/F)  : 47.9C/116.6F
                                            Fan 1 Speed          : 1185 RPM (34%)
                                            Fan 2 Speed          : 1065 RPM (31%)
      4  J9829A CN6AK36XXX Powered          AC Power Consumption : 88 Watts
                                            AC MAIN Voltage      : 230 Volts
                                            Power Supplied       : 68 Watts
                                            Inlet Temp (C/F)     : 28.1C/82.4F
                                            Internal Temp (C/F)  : 44.2C/111.2F
                                            Fan 2 Speed          : 1185 RPM (34%)
       4 /  4 supply bays delivering power.
       Currently supplying 258 W / 4400 W total power.
       Refer to command's help option for field definitions
    The example above was taken from an Aruba 5412R zl2 (KB.16.05.0007) equipped with with four PS modules and no PoE PD connected.
  • 3.  RE: Aruba 5400 switch PSU temperature sensor
    Posted Apr 24, 2020 09:33 AM
    Hello parnassus,
    Thank you for the information. I fear this might be a firmware version issue why I can't see it. We're currently running KB.16.02.0028. Thanks for the help!
  • 4.  RE: Aruba 5400 switch PSU temperature sensor
    MVP GURU
    Posted Apr 24, 2020 12:09 PM
    Yep, that command/option was made available since 16.03 (on Aruba 3810M and 5400R zl2 only) so I fear that you shall eventually evaluate an upgrade (suggested target: KB.16.10 [*]) to have that command added to your ArubaOS-Switch's grammar.
    [*] Clearly if your switch is actually running on KB.16.02.0028 it means that you are keen to use a "conservative" software version instead of using a cutting-edge one (there are, as always, pro/cons in doing that).
