Wired Intelligent Edge
Aruba 5406r zl2 act as ntp server and client
  • 1.  Aruba 5406r zl2 act as ntp server and client
    Posted Jun 16, 2018 02:38 PM
    Is it supported, that Aruba Switch 5406 with firmware KB.16.05.0007 act as NTP client and server?
    My design:
    Aruba 5406 is Core switch with 10 VLAN's (one of them is Management vlan). On this switch I synchronize with outside (public) ntp server with Management vlan as source. (Works and get correct time).
    Then I have 15 access switches with the same management vlan. I would like to implement so that this switches synchronized with my Core switch (aruba 5406). But when I configure it (the "show ntp status"  show as Not Synced). The time is not correct.
    Please help.
    Thank you.
  • 2.  RE: Aruba 5406r zl2 act as ntp server and client
    Posted Jun 18, 2018 10:13 AM
    Hi, these switches support NTP client and all the needed features. These switches can't be enabled as NTP server. Hope this will answer you're question.
  • 3.  RE: Aruba 5406r zl2 act as ntp server and client
    Posted Jun 18, 2018 03:23 PM
    Hi Blaz,
    The switch acts as a NTP Client.
    There are two solutions for the given Design.
    1. You can Sync all your switches to the Public NTP server.
    2. You can setup a Local NTP server and Sync all the switches with the internal NTP server.
    Hope it helps
