Cloud Managed Networks
Aruba 6000 help me understand vlan and route
This thread has been viewed 33 times
  • 1.  Aruba 6000 help me understand vlan and route
    Posted Aug 02, 2024 10:25 AM
    Hello, first sorry for my english it's not my native language..
    I'm prety new with Aruba OS CX and routes also, so maybe you could help me to understand why my config did not work and why after few edits it start work.
    Equipment:
    Router with WAN port (MPLS network)
    Directly to Router plugged Aruba 6000 (int 1/1/24)
    Are 3 vlan.
    130
    135
    230 (this vlan in huawei configured by acl isolated from others vlans)
    My first config in 6000 was (copied just related lines)
    vlan 130
    vlan 135
    vlan 230
    interface 1/1/1
        no shutdown
        vlan access 130
        loop-protect
        loop-protect action tx-rx-disable
    interface 1/1/15
        no shutdown
        vlan trunk native 135
        vlan trunk allowed 135,230
        loop-protect
    interface 1/1/23
        no shutdown
        vlan access 230
        loop-protect
    interface 1/1/24
        no shutdown
        vlan trunk native 1
        vlan trunk allowed all
        loop-protect
    interface vlan 130
        ip address 192.168.132.250/24
    ip route 0.0.0.0/0 192.168.132.254
    My IP route was:
    Prefix               Nexthop           Interface     VRF(egress)   Origin/  Distance/    Age
        Type     Metric
    0.0.0.0/0           192.168.132.254  vlan130       -                 S         [1/0]        20h:32m:52s
    192.168.132.0/24    -                vlan130       -                 C         [0/0]        -
    192.168.132.250/32  -                vlan130       -                 L         [0/0]        -
    With this config from other network I successfully can reach devices on int 1/1/1 and device on 1/1/15 vlan 135. Also i can ssh to switch.
    In int 1/1/15 also is configured wifi ssid with tagged 230 vlan (devices got IP from DHCP in huawei).
    In int 1/1/23 plugged devices also got IP.
    But from switch and also from huawei router I can't ping and reach vlan 230 devices. After a lot of googling I created another SVI:
     interface vlan 230
        ip address 14.1.232.250/24
    My IP routes become:
        Type     Metric
    0.0.0.0/0           192.168.132.254  vlan130       -                 S         [1/0]        20h:35m:39s
    14.1.232.0/24       -                vlan230       -                 C         [0/0]        -
    14.1.232.250/32     -                vlan230       -                 L         [0/0]        -
    And finally i could ping to vlan 230 device from switch and can reach them from router
    Why this happened?
    Because my switch routed vlan packets to primary route? And because of  ACL packet were dropped by router?
    If yes, so why my primary route routed other vlan packets?
    Sorry if in  this writing are a lot of mess, i learning.
  • 2.  RE: Aruba 6000 help me understand vlan and route
    Posted Aug 05, 2024 12:24 AM
    From what I can understand in your details it sounds like the ACLs on the router are likely to be where the traffic is being stopped. If you add an SVI on the switch for VLAN 230 and then can reach that VLAN from the switch (directly) then that makes sense. I can't explain why the router could not reach devices on VLAN 230 prior to adding the SVI, however.
  • 3.  RE: Aruba 6000 help me understand vlan and route
    Posted Aug 05, 2024 12:48 AM
    But maybe you can explain me how IP routing works
    My IP route table now is:
        Type     Metric
    0.0.0.0/0           192.168.132.254  vlan130       -                 S         [1/0]        03d:15h:57m
    I created static route for management access. But if I understand correctly, after my first SVI (vlan 130) and IP route creation my switch started route packet self, yes?
    And when in switch not was SVI 230 it routed packets to my static route GW (vlan 130) ? And because in router vlan 230 is isolated packets was drooped.
    After I created SVI 230 in switch, switch knows that vlan 230 it's 'own' network and routed those packet to connected vlan route ignoring static route?
    Maybe without any static route all traffic would be forwarded to route directly ? But without static route I can't use ssh from other network...
    And if I created SVI vlan 230 in switch (witch one is isolated by acl in router) how I still can't reach others vlan
    I'm little bit confused with these routes and SVI in switch...,
    And more confused me if vlan 230 isolated by acl in router and I created SVI 230 in switch. So how i still not able ping to vlan 230 devices from other same switch vlan with SVI? If I understand corectlly,  switch doing all L3 switching between vlans with SVI?
