Wired Intelligent Edge
Aruba 6000 R8N87A automatic backup
  • 1.  Aruba 6000 R8N87A automatic backup
    Posted Feb 22, 2023 04:42 AM
    I have read in a post that it is possible to use aruba netedit to back up the config of a Aruba 6000 automatically. I have read in the manual from netedit:
    supported are:
    • Aruba CX 6000 Switch Series • Aruba CX 8000 Switch Series
    Build when i try to add de device in netedit, it says unsupported. Any ideas?
    I have also a couple of 2930F switches, where i am using a job in combination with tftp. What should be a better solution to use? Preferable no cloud solutions.
  • 2.  RE: Aruba 6000 R8N87A automatic backup
    Posted Feb 22, 2023 10:13 AM
    No idea about Netedit not working with CX6000 and I don't have any to test with, but I can confirm that it works fine with CX6100 and that should be same featureset.  If you're using it in a licensed manner, I would suggest asking support.
    For your legacy switches, I would recommend either RANCID or NeDi.
  • 3.  RE: Aruba 6000 R8N87A automatic backup
    Posted Feb 22, 2023 10:20 AM
    Hello all,
    along with RANCID and NeDi, I'd personally add to the list Oxidized
    https://github.com/ytti/oxidized
    Which basicaly is a RANCID replacement.
    Regards
    Gino Gamba
