Wired Intelligent Edge
Aruba 6100 CX but no netedit in central?
This thread has been viewed 37 times
  • 1.  Aruba 6100 CX but no netedit in central?
    Posted Sep 01, 2021 07:05 AM
    Can't seem to find netedit for 6100?
    Is that not supported yet?
    Sebastian Johansen
  • 2.  RE: Aruba 6100 CX but no netedit in central?
    MVP GURU
    Posted Sep 01, 2021 07:21 AM
    Hello Sebastian, the Aruba 6100 Switch series was supported by Aruba NetEdit since Aruba NetEdit 2.0.11 (January 2021). As of today Aruba NetEdit 2.1.1 is available so the Aruba 6100 Switch series is necessarily still supported.
    Aruba NetEdit 2.1.1 supports up to ArubaOS-CX 10.08.0001, 10.07.0020 and 10.06.0140 software builds.
    Currently Aruba 6100 Switch series can be (and it is expected to) run with these recent ArubaOS-CX software builds:
    1. ArubaOS-CX 10.08.0001
    2. ArubaOS-CX 10.07.0021
    3. ArubaOS-CX 10.06.0140
    Davide Poletto
  • 3.  RE: Aruba 6100 CX but no netedit in central?
    Posted Sep 01, 2021 07:40 AM
    Thanks for the fast reply, i would need to update my 6100  CX to alteast FW verison 10.06.0140 version? Currenlty on 10.06.0110 as it is the recommended one
    Sebastian Johansen
  • 4.  RE: Aruba 6100 CX but no netedit in central?
    Posted Sep 01, 2021 08:27 AM
    Checked the releasenotes, and i can see that central only support template based configuration.. strange that they support netedit inn central for 6200 but not for 6100
    Sebastian Johansen
  • 5.  RE: Aruba 6100 CX but no netedit in central?
    Posted Sep 01, 2021 08:49 AM
    Hi Sebastian,
    I believe your question is about Multi-Editor support for 6100.
    As of now 6100 supported only with template group configurations - here and the recommended software version for 6100 to work with Aruba Central is 10.06.0110 or later.
    Raghunandan H.A.
  • 6.  RE: Aruba 6100 CX but no netedit in central?
    Posted Sep 01, 2021 08:52 AM
    That is correct, will multi edit be supported for 6100 in the near further?
    Sebastian Johansen
  • 7.  RE: Aruba 6100 CX but no netedit in central?
    Posted Sep 02, 2021 03:15 AM
  • 8.  RE: Aruba 6100 CX but no netedit in central?
    Posted Jan 26, 2022 03:29 PM
    As of Central version 2.5.4 the 6100 now supports UI config and thus multi-edit.
    https://help.central.arubanetworks.com/latest/documentation/online_help/content/nms/aos-cx/supported-platforms/supported-switches-cx.htm
    Jeremy Bradrick
