Network Management
Aruba 6100 series switch IMC, Unknown
  • 1.  Aruba 6100 series switch IMC, Unknown
    Posted 21 hours ago
    Hi all, i have tried to add 2 new 6100 series switches to IMC and both show as unknown in IMC. I am using SNMPv3 / SSH and Restful API. I have checked over and all my settings test ok within IMC fine. IMC is only one update behind the lastest release and the switch i installed the latest firmware on rebooted and tested again with same result.
    no change from re adding device and also unmanaged/managed.
    All the switch information is shown ok within IMC except serial number and software version.
    Has anyone had this and any pointers ???
    thank you
    Paul
  • 2.  RE: Aruba 6100 series switch IMC, Unknown
    MVP GURU
    Posted 21 hours ago
    Hi, you should update to latest E0710P04, try that first.
