ARUBA 620 CAPTIVE PORTAL
  • 1.  ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 06:10 AM
    I am trying to setup captive portal for one of SSID, the users get authenticated via Radius.
    everything on Wi-Fi side working but captive portal is not opening.
    I have a profile setup for Captive portal and it is linked to initial role, Logon but nothing happens when a user connects to that particular SSID.
    I can post the output if required.
    Attachment(s)
    txt
    aruba show rights.txt   9 KB 1 version
  • 2.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 06:24 AM
    Did you create the Captive Portal using the WLAN Wizard?  It is easier that way.  Creating it manually involves too many steps....
  • 3.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 06:28 AM
    not sure it was already created in the past, I just linked it to the profile,
    i have attached the output in first post, if you could check it please.
  • 4.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 06:33 AM
    I don't see any problem with that ACL, but there is more to it.  Can your client get an ip address and resolve DNS?  Is your client getting that initial role when it associates?
  • 5.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 06:43 AM
    users get ip address and browse internet fine
    this is the CP profile for aruba, once connected to Wi-Fi, I am unable to reach it.
    https://192.168.6.2/cgi-bin/login?profile=test_mac_cp
  • 6.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 07:19 AM
    Users browse the internet just fine, because they are not being placed into the correct initial role.  The initial role is assigned by the AAA profile.  That initial role should be the first role that you pasted into the forum.
  • 7.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 07:31 AM
    pl see attached
    Attachment(s)
  • 8.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 07:35 AM
    Are you using the correct AAA profile?  If you type "show user", the profile column will tell you what AAA profile is being used for that user.  Change that AAA profile's initial role to that logon role.
  • 9.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 07:40 AM
    yes looks fine
    10.6.1.146      d0:57:7b:22:73:97  host/LAP332  authenticated  00:02:23    802.1x            10Lath_AP1  Wireless  STC/d8:c7:c8:ad:ea:d2/g-HT        STC-aaa_prof             tunnel        Win 10
  • 10.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 07:44 AM
    That device looks like it logged in using 802.1x and not captive portal.
  • 11.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 07:48 AM
    thats correct
    sorry my bad
    I want users redirected to CP after successful login, is that possible?
  • 12.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 07:51 AM
    basically we want user to install a cert from firewall once logged in
    So my plan is to redirect user to that page.
  • 13.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 07:56 AM
    You should change the default 802.1x role in the AAA profile to logon.
  • 14.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 08:29 AM
    do you mean the
    Default machine and user role?
    see attached
  • 15.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 09:08 AM
    No.
    In the AAA profile, the dot1x default role should be logon.
  • 16.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Aug 15, 2018 10:01 AM
    right When i change 802.1X Authentication Default Role to logon
    it is opening page but going to below url and showing blank page
    https://securelogin.arubanetworks.com/cgi-bin/login?
  • 17.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Sep 04, 2018 05:11 AM
    can anyone help with this, any idea why it is keep going to
  • 18.  RE: ARUBA 620 CAPTIVE PORTAL
    Posted Sep 04, 2018 07:17 AM
    sorted now thanks
