Aruba 620 files
  • 1.  Aruba 620 files
    Posted Aug 28, 2014 03:57 AM
    I want to upgrade 620 os 6.1 to 6.3 but not enough memory ,so i want to delete some files
    which files can i delete ,and which is unuse
    (Aruba620) #show storage
    Filesystem Size Used Available Use% Mounted on
    /dev/mtdblock11 156.0M 122.6M 33.4M 79% /flash
    none 300.0M 1.9M 298.1M 1% /tmp
    /dev/mtdblock9 50.0M 24.6M 25.4M 49% /mnt/img0
    /dev/mtdblock10 50.0M 34.0M 16.0M 68% /mnt/img1
    (Aruba620) #dir
    -rw-r--r-- 1 root root 27433 Aug 27 07:26 default.cfg
    -rw-r--r-- 1 root root 1794 May 8 09:02 demo_license
    drwxr-xr-x 3 root root 0 Apr 3 04:44 fieldCerts
    -rw-r--r-- 1 root root 140216 Aug 27 06:44 flashbackup.tar.gz
    -rw-r--r-- 1 root root 20872 Apr 9 07:15 original.cfg
    drwx------ 2 root root 0 Mar 13 10:12 tpm
  • 2.  RE: Aruba 620 files
    Posted Aug 28, 2014 04:01 AM
    You can delete the flashbackup and also you should do a tar logs tech-support and then delete the resulting logs.tar file.
