Wired Intelligent Edge
Aruba 6300 SSH access restriction
This thread has been viewed 50 times
  • 1.  Aruba 6300 SSH access restriction
    Posted Nov 29, 2021 11:05 AM
    Hi
    I have Aruba 6300m Switch and I want to configure SSH restriction for specific IP only, I have searched in the configuration guide but I couldn't find anything for this.
    is there any way to restrict SSH access?
    Qais Sherfeed
  • 2.  RE: Aruba 6300 SSH access restriction
    Posted Nov 29, 2021 05:04 PM
    yes you need to configure a control plane ACL to restrict ssh, https access to our AOS-CX switches.
  • 3.  RE: Aruba 6300 SSH access restriction
    Posted Nov 30, 2021 05:06 AM
    Thanks, Ariyap
    it's clear
    Qais Sherfeed
  • 4.  RE: Aruba 6300 SSH access restriction
    Posted Nov 30, 2021 03:05 AM
    Hi Qais,
    yes, ariyap is correct - you can use the control plane ACL. I was searching for an example a few days ago and here is a guide for you:
    https://www.arubanetworks.com/techdocs/AOS-CX/10.07/PDF/AOS-CX_10-07_hardening.pdf
    Please refer to page 10, section "Control plane ACLs".
    Stanislav Naydenov
  • 5.  RE: Aruba 6300 SSH access restriction
    Posted Nov 30, 2021 05:08 AM
    Thanks, Stanislav
     that's what I was looking for
    thank you
    Qais Sherfeed
  • 6.  RE: Aruba 6300 SSH access restriction
    Posted Nov 30, 2021 04:22 AM
    Hi, this is my template for hardenning aruba CX swicth :
    banner motd !
    *                           RESTRICTED ACCES                                  *
    password complexity
        enable
        history-count 5
        minimum-length 10
        position-changes 5
        lowercase-count 2
        uppercase-count 2
        special-char-count 2
        numeric-count 2
    user admin group administrators password plaintext Y0urH@rdP@$$!
    no ip icmp redirect
    no cdp enable
    cli-session
        timeout 15
    ! Disable aruba central if not used :
    aruba-central
        disable
    ! SSH HARDENNING - disable weak algo :
    ssh server vrf default
    no ssh server vrf mgmt
    ssh ciphers chacha20-poly1305@openssh.com aes128-ctr aes192-ctr aes256-ctr aes128-gcm@openssh.com aes256-gcm@openssh.com
    ssh host-key-algorithms ecdsa-sha2-nistp384 ecdsa-sha2-nistp521 ssh-ed25519 rsa-sha2-256 rsa-sha2-512
    ssh key-exchange-algorithms curve25519-sha256 curve25519-sha256@libssh.org diffie-hellman-group-exchange-sha256 diffie-hellman-group16-sha512 diffie-hellman-group18-sha512 diffie-hellman-group14-sha256
    ssh macs hmac-sha2-256-etm@openssh.com hmac-sha2-512-etm@openssh.com
    ! RESTRICT ACCESS TO SWITCH :
    access-list ip acl-ControlPlane
        comment *** NETEDIT ***
        permit tcp 10.X.X.X any eq 22
        permit tcp 10.X.X.X any eq 443
        permit udp 10.X.X.X any eq 161
        comment *** SSH ADMIN ***
        permit tcp 10.X.X.X/255.255.255.0 any eq 22
        comment *** HTTPS admin ***
        comment *** SNMP ***
        permit udp 10.X.X.X/255.255.255.0 any eq 161
        comment *** LOGGING ***
        permit udp any 10.X.X.X eq 514
        comment *** NTP ***
        permit udp any 10.X.X.X eq 123
        comment *** DENY ***
        deny tcp any any eq 22
        deny tcp any any eq 443
        deny tcp any any eq 80
        deny udp any any eq 123
        deny udp any any eq 514
        deny udp any any eq 161
        comment *** PERMIT OTHER ***
        permit any any any log count
    apply access-list ip acl-ControlPlane control-plane vrf default
    ip source-interface all interface vlan1
    https-server rest access-mode read-only
    https-server vrf default
    no https-server vrf mgmt​
    Laurent from Brest / France
    Network Engineer
  • 7.  RE: Aruba 6300 SSH access restriction
    Posted Nov 30, 2021 05:10 AM
    Thanks, Whitehawk29FR
    You made it easier
    Thank you
    Qais Sherfeed
  • 8.  RE: Aruba 6300 SSH access restriction
    Posted Nov 30, 2021 04:28 PM
    and you can always refer to the CX hardening guide
